ATtinySerialOut. Compilation error 'initTXPin'
Hello.
When compiling the ATtinySerialOutExample.ino example (attached) for the ATtinySerialOut library, I get the error: " 'initTXPin' was not declared in this scope".
What am I doing wrong?
The error appears on line 41 of the attached program.
Board ATtiny13, Arduino IDE 2.3.2
Full documentation of the library is here: GitHub - ArminJo/ATtinySerialOut: Minimal bit-bang send serial 38400/115200 baud for 1MHz or 115200/230400 baud for 8 or 16MHz ATtiny clock
 * ATtinySerialOutExample.cpp
 * Example for using ATtinySerialOut library
 *  Copyright (C) 2015-2021  Armin Joachimsmeyer
 *  Email: armin.joachimsmeyer@gmail.com
 *  This file is part of TinySerialOut https://github.com/ArminJo/ATtinySerialOut.
 *  TinySerialOut is free software: you can redistribute it and/or modify
 *  it under the terms of the GNU General Public License as published by
 *  the Free Software Foundation, either version 3 of the License, or
 *  (at your option) any later version.
 *  This program is distributed in the hope that it will be useful,
 *  but WITHOUT ANY WARRANTY; without even the implied warranty of
 *  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
 *  See the GNU General Public License for more details.
 *  You should have received a copy of the GNU General Public License
 *  along with this program. If not, see <http://www.gnu.org/licenses/gpl.html>.
#include <Arduino.h> // required for main()
 * You can specify TX_PIN here (before the line #include "ATtinySerialOut.hpp")
//#if defined(__AVR_ATtiny87__) || defined(__AVR_ATtiny167__)
//#define TX_PIN PIN_PA1 // (package pin 2 / TXD on Tiny167) - can use one of PIN_PA0 to PIN_PA7 here
//#elif defined(__AVR_ATtiny84__)
//#define TX_PIN PIN_PA1 // can use one of PIN_PA0 to PIN_PA7 and PIN_PB0 to PIN_PB2 here
//#else
//#define TX_PIN PIN_PB2 // (package pin 7 on Tiny85) - can use one of PIN_PB0 to PIN_PB4 (+PIN_PB5) here
//#endif
void setup(void) {
    initTXPin();
    Serial.println(F("START " __FILE__ " from " __DATE__ "\r\nUsing library version " VERSION_ATTINY_SERIAL_OUT));
    writeString("OSCCAL=");
    writeUnsignedByteHexWithPrefix(OSCCAL);
void loop(void) {
    static uint8_t tIndex = 0;
     * Example of 3 byte output. View in combined ASSCI / HEX View in HTerm (http://www.der-hammer.info/terminal/)
     * Otherwise use writeUnsignedByteHexWithoutPrefix or writeUnsignedByteHex
    write1Start8Data1StopNoParityWithCliSei('I');
    writeBinary(tIndex);                    // 1 byte binary output
    writeUnsignedByte(tIndex);              // 1-3 byte ASCII output
    writeUnsignedByteHexWithPrefix(tIndex); // 4 byte output
    writeUnsignedByteHex(tIndex);           // 2 byte output
    write1Start8Data1StopNoParityWithCliSei('\n');
     * Serial.print usage example
    Serial.print("I=");
    Serial.print((char) tIndex);
    Serial.print(" | ");
    Serial.print(tIndex);
    Serial.print(tIndex, HEX);
    Serial.printHex(tIndex);
    Serial.println(tIndex);
    tIndex++;
    delay(100);
You call the function up the top of setup(), but it’s not written, defined or declared anywhere.
There should be a function -
void initTXPin (…) somewhere in your sketch, with the appropriate code.
This program code is an exact copy of the sample sketch that the library author wrote.
The declaration of the called function initTXPin() should be in the library itself, i.e. #include "ATtinySerialOut.hpp"
It is defined in there:
However, there are a lot of #ifdef statements which may mean it's not being enabled when compiling. I don't have ATtiny13 support installed so I can't easily try compiling for that processor.
I contacted the author of this library, unfortunately the guy turned out to be a bit of a jerk, so I was unable to bring the matter to a positive conclusion.
In connection with the above, I state that the ATtinySerialOut library is not suitable for working with ATtiny13, at least in the form it is currently available.
Topic to be closed.
