Hey! I am writing to you from Ukraine through a translator. Tell me, did you manage to connect a new steering wheel using LIN2, or rather read the buttons and make an emulator for a new steering wheel? I have Mega256 and Lin transiver TJA1020. Audi a7 2012 car and new steering wheel from Audi a5 2017 LIN2
i am trying this code with my Audi and i am using UNO board at this time. When i compile this code i get the below error log
*VehicleSimulator = (HardwareSerial *)&Serial2,
C:\Users\rahul.chandrashekar\Downloads\volvo_linbus-master\volvo_linbus\volvo_linbus.ino:27:44: note: suggested alternative: 'Serial'
Serial
C:\Users\rahul.chandrashekar\Downloads\volvo_linbus-master\volvo_linbus\volvo_linbus.ino: In function 'void setup()':
volvo_linbus:48:5: error: 'SerialConsole' was not declared in this scope
SerialConsole->begin(115200);
volvo_linbus:60:5: error: 'UCSR1C' was not declared in this scope
UCSR1C = _BV(UCSZ11) | _BV(UCSZ10); //async operation, 8N1
C:\Users\rahul.chandrashekar\Downloads\volvo_linbus-master\volvo_linbus\volvo_linbus.ino:60:5: note: suggested alternative: 'UCSR0C'
UCSR0C
In file included from c:\users\rahul.chandrashekar\appdata\local\arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7\avr\include\avr\io.h:99:0,
from c:\users\rahul.chandrashekar\appdata\local\arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7\avr\include\avr\pgmspace.h:90,
from C:\Users\rahul.chandrashekar\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino/Arduino.h:28,
from C:\Users\RAHUL~1.CHA\AppData\Local\Temp\arduino_build_351419\sketch\volvo_linbus.ino.cpp:1:
volvo_linbus:60:18: error: 'UCSZ11' was not declared in this scope
C:\Users\rahul.chandrashekar\Downloads\volvo_linbus-master\volvo_linbus\volvo_linbus.ino:60:18: note: suggested alternative: 'UCSZ01'
volvo_linbus:60:32: error: 'UCSZ10' was not declared in this scope
C:\Users\rahul.chandrashekar\Downloads\volvo_linbus-master\volvo_linbus\volvo_linbus.ino:60:32: note: suggested alternative: 'UCSZ00'
volvo_linbus:61:5: error: 'UBRR1' was not declared in this scope
UBRR1 = 51; //19.2kbaud UBRR = (16MHz / 16 x 19200) - 1
C:\Users\rahul.chandrashekar\Downloads\volvo_linbus-master\volvo_linbus\volvo_linbus.ino:61:5: note: suggested alternative: 'UBRR0'
UBRR0
volvo_linbus:62:5: error: 'UCSR1B' was not declared in this scope
UCSR1B = _BV(RXCIE1) | _BV(RXEN1) | _BV(TXEN1); //enable the UART1 receiver & transmitter and UART1 RX interrupt
C:\Users\rahul.chandrashekar\Downloads\volvo_linbus-master\volvo_linbus\volvo_linbus.ino:62:5: note: suggested alternative: 'UCSR0B'
UCSR0B
volvo_linbus:62:18: error: 'RXCIE1' was not declared in this scope
C:\Users\rahul.chandrashekar\Downloads\volvo_linbus-master\volvo_linbus\volvo_linbus.ino:62:18: note: suggested alternative: 'RXCIE0'
volvo_linbus:62:32: error: 'RXEN1' was not declared in this scope
C:\Users\rahul.chandrashekar\Downloads\volvo_linbus-master\volvo_linbus\volvo_linbus.ino:62:32: note: suggested alternative: 'RXEN0'
volvo_linbus:62:45: error: 'TXEN1' was not declared in this scope
C:\Users\rahul.chandrashekar\Downloads\volvo_linbus-master\volvo_linbus\volvo_linbus.ino:62:45: note: suggested alternative: 'TXEN0'
C:\Users\rahul.chandrashekar\Downloads\volvo_linbus-master\volvo_linbus\volvo_linbus.ino: In function 'void linRXStateMachine()':
volvo_linbus:136:34: error: 'FE1' was not declared in this scope
if( (s & _BV(FE1)) && (b == FRAME_BYTE) )
C:\Users\rahul.chandrashekar\Downloads\volvo_linbus-master\volvo_linbus\volvo_linbus.ino:136:34: note: suggested alternative: 'FE0'
volvo_linbus:155:35: error: 'FE1' was not declared in this scope
if( !(s & _BV(FE1) ) )
C:\Users\rahul.chandrashekar\Downloads\volvo_linbus-master\volvo_linbus\volvo_linbus.ino:155:35: note: suggested alternative: 'FE0'
volvo_linbus:178:33: error: 'SerialConsole' was not declared in this scope
SerialConsole->println( "Message invalid" );
C:\Users\rahul.chandrashekar\Downloads\volvo_linbus-master\volvo_linbus\volvo_linbus.ino: In function 'void USART1_RX_vect()':
volvo_linbus:217:9: error: 'UCSR1A' was not declared in this scope
s = UCSR1A; //need to be in this order (read status then received data) to get the right status value
C:\Users\rahul.chandrashekar\Downloads\volvo_linbus-master\volvo_linbus\volvo_linbus.ino:217:9: note: suggested alternative: 'UCSR0A'
UCSR0A
volvo_linbus:218:10: error: 'UDR1' was not declared in this scope
ch = UDR1;
C:\Users\rahul.chandrashekar\Downloads\volvo_linbus-master\volvo_linbus\volvo_linbus.ino:218:10: note: suggested alternative: 'UDR0'
ch = UDR1;
UDR0
C:\Users\rahul.chandrashekar\Downloads\volvo_linbus-master\volvo_linbus\volvo_linbus.ino: In function 'void DumpFrame()':
volvo_linbus:239:13: error: 'SerialConsole' was not declared in this scope
SerialConsole->write( '0' );
volvo_linbus:240:9: error: 'SerialConsole' was not declared in this scope
SerialConsole->print( b, HEX );
volvo_linbus:244:5: error: 'SerialConsole' was not declared in this scope
SerialConsole->println();
Using library SoftwareSerial at version 1.0 in folder: C:\Users\rahul.chandrashekar\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SoftwareSerial
exit status 1
'Serial2' was not declared in this scope
Hi
when i run this code on my UNO board, i get the following compilation error
Serial
UCSR0C
UBRR0
UCSR0B
UCSR0A
ch = UDR1;
ch = UDR1;
UDR0
exit status 1
That's because that code was written for a Mega2560 Arduino, not an Uno.
Thanks -> the write command worked fine. But i have issues reading the frame from my Transreciever.
i see that the below function is been called, but when i debug the frames and messages. it is always "0". The transreciever is sending me the following message
"0x01 0xFF 0x08 0x57 0x44 0xFF 0x03 0x90 0xB2"
//process LIN messages
linRXStateMachine();
void linRXStateMachine( void )
static uint8_t
stateLIN = SEEK_FRAME_START; //LIN state variable
uint16_t
rx; //combo of status and received byte
uint8_t
b, //rx'd byte
s, //status
tempHead; //temporary receive buffer head pointer value
//read the head pointer
noInterrupts();
tempHead = rxHeadPtr;
interrupts();
//if not the same as the tail pointer there are bytes to process
if( tempHead != rxTailPtr )
do
//read the combination status and rx'd byte from the buffer
rx = gruRxBuffer[rxTailPtr];
//split into the byte and status
b = (uint8_t)(rx & 0xff);
s = (uint8_t)((rx >> 8) & 0xff);
switch( stateLIN )
case SEEK_FRAME_START:
//waiting for a break indication (framing error; FE1 bit in status register)
//start of frame == framing error and rx'd a 0x00
stateLIN = SEEK_SYNC_BYTE;
case SEEK_SYNC_BYTE:
//byte immediately following the start condition should be a SYNC byte
if( b == SYNC_BYTE )
//got it; reset the LIN frame
frame.reset();
//and go get the frame
stateLIN = RECEIVE_FRAME_DATA;
}//if
case RECEIVE_FRAME_DATA:
//if we don't see a framing error
//just append the received byte to the frame
frame.append_byte( b );
}//if
//we see a break here; if we rx'd a 0x00 we
//are looking at the start of the next frame so we can process
//the one sitting in the buffer
if( b == 0x00 )
//if the frame is valid... frame.isValid()
if(true )
//show it
DumpFrame();
}//if
//frame check failed
}//else
//got back and wait for the sync byte
}//if
//got a framing error but not an accompanying 0x00
//go to seek a frame start state
}//else
}//else
}//switch
//after each pass, advance the tail pointer...
rxTailPtr = (rxTailPtr + 1) & (BUFF_SIZE - 1);
//until we match the head pointer when we started this
}while( rxTailPtr != tempHead );
}//if
}//linRXStateMachine
ISR( USART1_RX_vect )
uint8_t
ch,
s;
//read the character and the status register
ch = UDR1;
//put the status byte in the most-sig. byte and the character in the least-sig byte of the word in the buffer
gruRxBuffer[rxHeadPtr] = (uint16_t)((s << 8) | ch);
//bump the head pointer
rxHeadPtr = (rxHeadPtr + 1) & (BUFF_SIZE - 1);
}//RX interrupt
void DumpFrame( void )
if (frame.get_byte(0) != WHEEL_SLAVE2)
SerialConsole->println(frame.get_byte(0));
return;
for (uint8_t idx = 0; idx<frame.num_bytes(); idx++)
uint8_t b = frame.get_byte(idx);
if( b <= 0xf )
SerialConsole->write( ' ' );
}//for
}//DumpFrame
Scope signal when i insert the probe in the Rx1 (pin number 17)
yes, it works with MCP2003/4
Are you seeing the state machine walking through the SEEK_FRAME_START (first pass) and/or the SEEK_SYNC_BYTE states?
Do you see the break/0x00 (FRAME_START) followed by the 0x55 (SYNC) bytes before you see the 0x01 0xFF 0x08 0x57... data?
Do you ever see it append a byte to the LIN buffer (e.g. a call to frame.append_byte( b ) )?
I noticed you changed:
if( frame.isValid() )
//show it
DumpFrame();
}//if
to
if(true )
//show it
DumpFrame();
}//if
You might place any received characters in a global byte within the ISR and just print those in loop. Maybe like:
volatile uint8_t prByte; // <-- add global variable
volatile bool bPrByte = false; // <-- add global variable
uint8_t
ch,
s;
ch = UDR1;
prByte = ch; // <-- add
bPrByte = true; // <-- add
}//RX interrupt
void loop( void )
//add this to print bytes as they are received in the ISR
if( bPrByte )
bPrByte = false;
SerialConsole->println( prByte, HEX );
}//if
}//loop
thanks -> the code works fine ;).
I have an another question -> i am using ESP32 with Atmega 2560 were i want to relay messages between these two boards. My objective is to pass the read LIN messages from Atmega to ESP32.
do you recommend me to use Serial3? or are their any other stratergy.
If I'm not mistaken the ESP32 has three HW serial ports; do you need the Mega2560 at all? Is it doing other stuff for your project?
You can use Serial3 of the Mega for this task but keep in mind that the ESP32 has 3.3V I/O so you'll need a level translator between the two.
Thanks for your inputs. I have Atmega2560 with ESP8266 and DIP switches.
Can I use only ESP8266 to read and write LIN? If yes this would be a super clean approach for me. Pls let me know on your comments and the tweak I will have to do to execute this
i am unable to compile the Atmega code in ESP board. I would be happy to use ESP32 board as it serves connectivity + HW read. Pls let me know if there are any tweaks to be done to support the write and read functionality in ESP board.
i get compilation errors for the ESP board in the following locations. possibly they are more Atmega libraries
ISR(USART1_RX_vect)
uint8_t
ch,
s;
ch = UDR1;
}//RX interrupt
//send a break on UART0 by disabling TX, setting the pin
//low and waiting >10 bit times at 19200
UCSR2B &= ~(_BV(TXEN2)); //disable transmitter to access pin
error message
Arduino: 1.8.19 (Windows 10), Board: "LOLIN(WEMOS) D1 R2 & mini, 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 921600"
volvo_linbus:217:5: error: expected constructor, destructor, or type conversion before '(' token
217 | ISR(USART1_RX_vect)
volvo_linbus:60:5: error: 'UCSR1C' was not declared in this scope; did you mean 'USRXC'?
60 | UCSR1C = _BV(UCSZ11) | _BV(UCSZ10); //async operation, 8N1
| USRXC
In file included from sketch\volvo_linbus.ino.cpp:1:
C:\Users\rahul.chandrashekar\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266/Arduino.h:157:25: note: in definition of macro '_BV'
157 | #define _BV(b) (1UL << (b))
61 | UBRR1 = 51; //19.2kbaud UBRR = (16MHz / 16 x 19200) - 1
62 | UCSR1B = _BV(RXCIE1) | _BV(RXEN1) | _BV(TXEN1); //enable the UART1 receiver & transmitter and UART1 RX interrupt
volvo_linbus:62:18: error: 'RXCIE1' was not declared in this scope; did you mean 'RTCIE'?
C:\Users\rahul.chandrashekar\Downloads\volvo_linbus-master\volvo_linbus\volvo_linbus.ino: In function 'void loop()':
volvo_linbus:90:9: error: 'UCSR2B' was not declared in this scope
90 | UCSR2B &= ~(_BV(TXEN2)); //disable transmitter to access pin
volvo_linbus:90:25: error: 'TXEN2' was not declared in this scope
volvo_linbus:143:34: error: 'FE1' was not declared in this scope
143 | if( (s & _BV(FE1)) && (b == FRAME_BYTE) )
volvo_linbus:162:35: error: 'FE1' was not declared in this scope
162 | if( !(s & _BV(FE1) ) )
C:\Users\rahul.chandrashekar\Downloads\volvo_linbus-master\volvo_linbus\volvo_linbus.ino: At global scope:
volvo_linbus:217:4: error: expected constructor, destructor, or type conversion before '(' token
exit status 1
option enabled in File -> Preferences.
The Mega code won't compile for the ESP32. For the Mega I used direct register access to set up the serial port and to access status registers etc by name. I've not done low-level ESP32 programming so I really can't help there. It can be done; you can get some pointers, say, here.
The logic can be the same as you have now, you just need to modify how the UART is set up and how break events are detected and handled.
It'd probably be easier to stick with the Mega to do the LIN interface with a quick and short serial interface to the ESP32 (level translation included) if you don't want to get into low-level ESP programming.
Thanks -> even i believe to stick with hybrid approach of Mega with ESP.
Based on what i understand i just need to use Serial3 to tramsit data to ESP and Serial to transmit data to Mega.
I hope this would be the approach. Should i do this within the loop? do you have some examples.
Because you're working in an automotive environment, I would wrap the LIN frame data in a packet for transmission to the ESP.
In this example for the Mega that you can integrate into your main program, I use a simple message structure with a preamble byte, a byte indicating the number of data bytes in the message, the LIN frame data and a simple checksum.
I use Serial3 and use TX interrupts to send the message so as not to block on sending it. You can use whatever you like.
On the ESP32 side, you'll set up a receive state machine to look for the preamble byte (0xA5), followed by the number-of-data byte. You can then receive that data and the checksum. The sum is the 8-bit addition of all bytes of the message except the checksum byte. If they match, you have a good message.
If you need more reliability you can change the checksum to a CRC (e.g.)
Code:
#define BUFF_SIZE 64
#define LIN_BUFF_SIZE 16
#define MSG_PREAMBLE 0xa5
const uint8_t
grLINPacket[] = { 0x50, 0x00, 0x80, 0xFF, 0x7F }; //test msg
//give the serial ports names to make things more human-readable
HardwareSerial
*SerialConsole = (HardwareSerial *)&Serial,
*ESPComm = (HardwareSerial *)&Serial3;
typedef struct structTXMsg
uint8_t msgPointer;
uint8_t msgChecksum;
uint8_t msgNumBytes;
uint8_t gruTxBuffer[BUFF_SIZE];
}sTXMsg_t;
//I create this structure only to emulate the LINFrame object
//this doesn't need to be copied into you code...
typedef struct structLinFrame
uint8_t grBuff[LIN_BUFF_SIZE];
uint8_t num_bytes;
uint8_t get_byte( uint8_t idx )
return grBuff[idx];
}//get_byte
}sLINFrame_t;
sTXMsg_t TXMsg;
sLINFrame_t frame;
void setup( void )
//set up mock LIN frame
frame.num_bytes = 5;
for( uint8_t i=0; i<5; i++ )
frame.grBuff[i] = grLINPacket[i];
//UART0 (default) serial console
//UART3 for comms to the ESP
ESPComm->begin(115200); //Serial3
}//setup
void loop( void )
//when you get a good frame, call DumpFrameToESP...
DumpFrameToESP();
delay(1000); //for demo purposes only; send test msg once a second
}//loop
// Send LIN frame to the ESP32
// Message structure is:
// 0xA5 message preamble
// 0xNN num data bytes
// 0xaa..0xnn data packet (LIN frame)
// 0xcc checksum
void DumpFrameToESP( void )
uint8_t
i;
//set up the message to send
TXMsg.gruTxBuffer[0] = MSG_PREAMBLE; //preamble
TXMsg.gruTxBuffer[1] = frame.num_bytes; //num data bytes in packet
for( i=0; i<frame.num_bytes; i++ ) //frame data
TXMsg.gruTxBuffer[2+i] = frame.get_byte(i);
TXMsg.msgNumBytes = 2 + frame.num_bytes; //preamble + num bytes + checksum + frame data
TXMsg.msgPointer = 1; //preamble has already gone so we point to next byte
TXMsg.msgChecksum = MSG_PREAMBLE; //checksum init to preamble (first byte sent)
//send the preamble and get the ball rolling
UCSR3A |= _BV(TXC3); //clear the TX flag
UDR3 = TXMsg.gruTxBuffer[0]; //send the preamble
UCSR3B |= _BV(TXCIE3); //enable the TX complete interrupt
}//DumpFrame
ISR( USART3_TX_vect )
uint8_t
bVal;
//last byte of message?
if( TXMsg.msgNumBytes == 1 )
//yes; send the checksum
bVal = TXMsg.msgChecksum;
}//if
//no; send the next msg byte and add it to the checksum
bVal = TXMsg.gruTxBuffer[TXMsg.msgPointer++];
TXMsg.msgChecksum = TXMsg.msgChecksum + bVal;
}//if
//transmit the byte
UDR3 = bVal;
//decrement the number of bytes left in the message
TXMsg.msgNumBytes--;
//if it's now zero, we've sent the last byte so...
if( TXMsg.msgNumBytes == 0 )
//...disable further TX interrupts
UCSR3B &= ~(_BV(TXCIE3));
}//if
}//UART3 TX interrupt
Logic analyzer:
appreciate this, can we have a call (15 mins) at your free time tomorrow? I am in EST and can work flexible based on your convenience.
i am able to transfer the LIN packet from ESP to Mega but the issue is sending the packet from Mega to LIN (via ESP8266 webpage).
for instance the earlier code in the forum had dumpframe() where the frame information was iterated. All i would need is to update the values to the ESP8266server running at (80) port.
if i implement DumpframeESP() -> what would be the hook to get that information to ESP (implementation at ESP to understand that it has recieved LIN packet.
for example - tried below implementation in ESP but did not yield consistent results.
void serialEvent() {
while(Serial1.available()) {
Serial.write( Serial1.read());
