Audio Delay
I did a bit of tweaking on my QuadRAM this morning to write and verify 8-byte (unsigned long long) data and got
Writing  512K QuadRAM (412432 usec)
Checking 512K QuadRAM (449696 usec)
512K test completed in 862128 usec.
So there may be some considerable merit to dxw00d's suggestion of Mega+QuadRAM.
Flub:
i just read that flash memory will die after about 10 000 times deleting a bit, does this mean arduinos and other micro controllers will die after being on for a while?
Well for one thing the whole memory doesn't die, it is organized into pages. Second, it is writing that wears it out, not reading. So you can program the Atmega chip 10000 times (ie. upload 10000 programs) before you have a problem. So you would have to program it 12 times a day, every day in the year, for over 2 years, before you had a problem.
In practice you normally get the program right and then deploy it.
Hello,
today i received those SRAM chips used in the link I posted before (23K256).
Ive seen here http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1290379685
that it already has been implemented a library for the arduino.
Because my board is different i took a look in the class the user "carl" has written and changed the parameters to my board.
this is the original code from carl for the teensy
#define setupSPI SPCR = 0x50 //Master mode, MSB first, SCK phase low, SCK idle low, clock/4
#define setupDDRB DDRB |= 0x2e  //set  SCK(13) MOSI(11) and SS1 , SS2 as outputs
#define selectSS1 PORTB &= ~0x04  //set the SS to 0 to select SRAM 1
#define deselectSS1 PORTB |= 0x04  //set the SS to 1 to deselect SRAM 1
#define selectSS2 PORTB &= ~0x02  //set the SS to 0 to select SRAM 2
#define deselectSS2 PORTB |= 0x02  //set the SS to 1 to deselect SRAM 2
this is how i adapted it to the teensy 1.0 (it doenst work yet)
#define setupDDRB DDRB |= 0x7  //set  SCK(13) MOSI(11) and SS1 , SS2 as outputs
#define setupDDRB DDRC |= 0x4
#define selectSS1 PORTB &= ~0x01  //set the SS to 0 to select SRAM 1
#define deselectSS1 PORTB |= 0x01  //set the SS to 1 to deselect SRAM 1
#define selectSS2 PORTC &= ~0x04  //set the SS to 0 to select SRAM 2
#define deselectSS2 PORTC |= 0x04  //set the SS to 1 to deselect SRAM 2
My SS1 Pin on the teensy is PB0 so i thought the binary to set this PiN as an output is just to set DDRB to 000 0001 thats (the bit on the right should be PB0 am I right?)
because the SCLK and MOSI PINS have to be outputs to the binary for DDRB is 0000 0111 which is the number 0x07 in Binary
for the other Bit stuff i did it the same way. But the test Program wont work
Do you think i have to change more in the code?
In the cpp file which contains the functions defined in the constructor of the .h file are some hex values too, but i dont know anything about them.
SRAM2class::SRAM2class()  //constructor
setupDDRB;
setupSPI;
deselectSS1;  //deselect if selected
deselectSS2;  //deselect if selected
selectSS1; //setup SRAM1
RWdata(0x05);//read status register
int Sreg = RWdata(0xff);//get status value
deselectSS1;
if(Sreg != 0x41) //are we in sequential mode
selectSS1;
RWdata(0x01); //write to status reg
RWdata(0x41);  //set sequencial  mode
deselectSS1;
}//end of set sequential mode for SRAM1
selectSS2; //setup SRAM2
deselectSS2;
selectSS2;
deselectSS2;
}//end of set sequential mode for SRAM2
}//end of constructor
void SRAM2class::writestream1(int address)
deselectSS1;  //deselect if still selected
deselectSS2;  //deselect if still selected
selectSS1; //select now
RWdata(0x02);//write to address
RWdata(address >> 8);//msb address
RWdata(address);//lsb address
}//end of write stream SRAM 1
void SRAM2class::writestream2(int address)
selectSS2; //select now
}//end of write stream SRAM 2
void SRAM2class::readstream1(int address)
RWdata(0x03);//read from address
RWdata(address >> 8);//read from address
RWdata(address);
}//end of read stream SRAM1
void SRAM2class::readstream2(int address)
RWdata(address);
}//end of read stream SRAM2
void SRAM2class::closeRWstream(void)
}//end of close RW stream
byte SRAM2class::RWdata(byte data)
 SPDR = data;
  while (!(SPSR & _BV(SPIF)))
  return SPDR;
}//end of RWdata
Does anyone see a Problem?
Another thing i am not sure with is:
carl used a 820 Ohm and 1.5kOhm voltage divider to get the 5 V signal from the arduino to 3,3V
Because i didnt have those values I took 6,2kOhm and 10kOhm.
is that too much ?
I got it working! now lets see if i can save audio in it.
But I have some problems with understanding the test code below.
in the for loop there is no occurance of the variable i, i had expected something like
for (unsigned int i=0; i< 32768; i++) {
SRAM2.RWdata(i);
but there is no i in between the brackets, how does it work then?
SRAM2.writestream1(0);  // write to SRAM 1
unsigned long stopwatch = millis(); //start stopwatch
for(unsigned int i = 0; i < 32768; i++)
SRAM2.RWdata(0x55); //write to every SRAM 1 address
Serial.print(millis() - stopwatch);
Serial.println("   ms to write full SRAM 1");
SRAM2.readstream1(0);   // start address from 0
if(SRAM2.RWdata(0xFF) != 0x55)  //check every address in the SRAM1
Serial.print("error in SRAM 1 at location  ");
Serial.println(i);
}//end of print error
if(i == 32767)
Serial.println("no errors for SRAM 1 in its 32768 bytes");
}//end of get byte
Serial.println(" ");
SRAM2.writestream2(0);  // write to SRAM 2
SRAM2.RWdata(0xaa); //write to every SRAM 2 address
Serial.println("   ms to write full SRAM 2");
SRAM2.readstream2(0);   // start address from 0
{javascript:void(0);
if(SRAM2.RWdata(0xFF) != 0xaa)  //check every address in the SRAM2
Serial.print("error in SRAM 2 at location  ");
Serial.println(i);
if(i == 32767)
Serial.println("no errors for SRAM 2 in its 32768 bytes");
}//end of get byte
I haven't read the datasheet, but some devices auto-increment. In other words, they assume that, if you don't specify a new address, you want to read/write to consecutive ones. This assumption saves sending an address for every single access when you might want to store 20 bytes in a row.
Im following this closely , as ill soon start working on a delay as well to implement in the dub siren im developing.
Thanks for sharing it all !!
Thats it Nick! Thank you!
Can someone help me out with creating a shift register from an octal d-type flipflop chip?
http://pdf1.alldatasheet.com/datasheet-pdf/view/28018/TI/SN74LS377N.html
I want to serially load it with 8 bit for the DAC
Do i have to connected Q1 with D2 and Q2 with D3 and Q3 with D4 etc ?
That sounds about right, Crossroads is always posting a circuit to do this.
Why not use the right chip for the job?
Rob
I dont wont to order via internet just to test the delay, because i try to find a 12 serial input dac later anyway
#include <SRAM2.h>
byte eingang;
unsigned int tcnt1= 65203;
unsigned int data = 0;
boolean clock = false;
boolean first = false;
 TCCR1A = 0;
 TCCR1B = 0;
 TIMSK1 = 0;
 TCCR1B = 1; //no prescaler
 TCNT1=tcnt1;
 TIMSK1 |= (1<<TOIE1); //set the timer on
 DDRD = 0x00; // set PORTD to all INPUTS - digital pins 0 - 7
 DDRC |= B11110000;
ISR(TIMER1_OVF_vect) {
  TCNT1=tcnt1;
  PORTC |= (1<<4); //generate 48kHz clock for ADC
  PORTC &= ~(1<<4);
  clock = true;
if (clock == true) {
 for (int i = 0; i<8; i++) {
   bitWrite(eingang,i,bitRead(PIND,7-i));
  PORTC |= (1<<5); //set DAC to HOLD
    if (bitRead(eingang,7-i)==1) { // 7- i because I dont know which is the MSB and which is the LSB
      PORTC |= (1<<6);
      PORTC &= ~(1<<6);
  PORTC |= (1<<7); // clock for the shift register made of the Dtype octal flip flop
  PORTC &= ~(1<<7);
PORTC &= ~(1<<5); //enable DAC
clock = false;
//end of loop
HI,
The thing is not workin yet, perhaps i made a mistake someone can see.
What i planned to do with this code is :
set a 16 bit timer to start from around 62000 with a prescaler of 1 so it needs 1/48000 Seconds to overflow.
on overflow set one pin high and low again -> this is the way to get the 48kHz clock for the ADC
then in the timer between the overflows, i want to fill a shift register, which later contains the bits for the DAC.
it should function like this (also described in the comments from the code):
first of all disable the DAC so that it wont do strange things on the loadup of the register. (btw the dac is the AD7528)
then in the for loop read every bit from the byte coming from the input port (portD) and verify if it is 1 or 0, if it is one then the input of the shift register
is set to 1, if its 0 it is set to zero.
after this comes the clock signal for the shift register, then the next bit from the input byte is loaded in the register, this is done the whole for loop long.
when it is finished the outputs of the shift register should contain the byte from the input. so the dac is ready to be enabled again.
Now what happens is a strange signal coming out of the DAC
http://www.analog.com/static/imported-files/data_sheets/AD7528.pdf
I connected the WR and the DAC A Pin to ground, the CS Pin is the pin i use to disable or enable the DAC.
for testing i connected the Vref A with 5 V RFbA is not connected.
the input data is connected with the shift register.
I have no idea why it doesnt work. i hope i forgot something obvious, can anyone see a mistake?
-Flo
You don't need an interrupt to output 48 KHz.
const byte LED = 9;
  pinMode (LED, OUTPUT);
  // set up Timer 1
  TCCR1A = _BV (COM1A0);  // toggle OC1A on Compare Match
  TCCR1B = _BV(WGM12) | _BV(CS10);   // CTC, no prescaler
  OCR1A =  166;       // compare A register value (167 * clock speed)
}  // end of setup
void loop() { }
That code outputs 48 KHz on pin 9.
well, does it matter if i use a compare match instead of the overflow to get the intervall i am aiming to?
Now i got the DAC workin. I made the mistake to use 15V as positive Power Supply for it, so every signal was low...
Now i see that it outputs a 24kHz resolution signal. Does anyone see the reason for this in the code?
EDIT: i found it myself i doubled the timer frequency... well but the thing is that the ADC frequency (set by the timer overflow) is twice 96kHz now.
I am trying to save those samples now.
measure = micros();
SRAM2.writestream1(32767);  //open writestream address from 0 to 32767
SRAM2.RWdata(73); //the byte to write to SRAM at current address
SRAM2.readstream1(032767;   //open readstream address from 0 to 32767
int data2 = SRAM2.RWdata(0xff);  //read byte from SRAM at current address
Serial.println(micros()-measure);
Serial.println(data2);  //check data
this code gives me around 28 µS for saving and reading the data. Now 48kHz means 1/48k = 20µS to Sample, save and output samples.
Now i have to buffer with the 512 kByte internal SRAM of the board.
i dont get how to use a buffer to compensate the lack of speed of the sram. can someone give me a hint to start with? my mind is not clear enough at the moment.
I can play (guitar) already an hear my delayed signal. There is digital noise, perhaps i can filter it out, but I want to get a better 12 bit dac anyway, so this is just for testing.
this is the recent code
#include <SRAM2.h>
byte eingang;
int test;
unsigned long measure;
unsigned int delays = 15000;
unsigned int delay_byte;
boolean first = true;
 TCCR1A = 0;
 TCCR1B = 0;
 TIMSK1 = 0;
 TCNT1=tcnt1;
 DDRC |= B11110000;
  TCNT1=tcnt1;
  PORTC |= (1<<4);
  PORTC &= ~(1<<4);
  eingang = PIND;
  clock = true;
  if (data > 32766) {
    data = 0;
    data++;
  first = false;
  PORTC |= (1<<5);
    if (bitRead(test,i)==1) {
      PORTC |= (1<<6);
      PORTC &= ~(1<<6);
    PORTC |= (1<<7);
    PORTC &= ~(1<<7);
  PORTC &= ~(1<<5);
  clock = false;
  SRAM2.writestream1(data);
  SRAM2.RWdata(eingang);
    if (data < delays) {
    delay_byte = 32766 - delays + data;
    delay_byte = data - delays;
    SRAM2.readstream1(delay_byte);
    test = SRAM2.RWdata(0xff);
Not sure by what you mean by lack of speed of RAM.
Audio speeds are glacial compared to just about any RAM device I've ever used.
yeah but this is this sram chip is a serial device and this code block takes 30µS
@Nick Gammon
Now I see the point of avoiding the interrupt. I didnt get your tip before :blush:
    delay_byte = 32767 - delays + data;
it seems like i have to split the recorder and playback section hardware wise in order to get the 48kHz resolution I aimed too.
My Dac has a Serial Output, perhaps I can make it write directly into the hardware chips, mh.
HI!
my teensy burned, so i bought a arduino nano .
Now i connected the ADC parallel to the arduino nano (12 bit all in all)
To begin I started to just read all inputs .
//#include <SRAM2.h>
unsigned int eingang;
unsigned int out;
int test = 1;
byte lbyte;
byte hbyte;
unsigned int delays = 3500;
//TIMER
 TCCR1A = 0;
 TCCR1B = 0;
 TIMSK1 = 0;
 TCNT1=tcnt1;
//CLOCK COMMAND PIN  = A2 PORTC 2
//BIT 1  =  A3  PORTC 3
//BIT 2  =  A4  PORTC 4
//BIT 3  =  A5  PORTC 5
//  PORTC EINGÄNGE einstellen 0011 1000
DDRC &= ~(0x38);
PORTC &= ~(0x38);
DDRC |= (1<<2);
//BIT 4  =  D10 PORTB 2
//BIT 5  =  D9  PORTB 1
//BIT 6  =  D8  PORTB 0
//  PORTB EINGÄNGE einstellen 0000 0111
DDRB &= ~(0x07);
PORTB &= ~(0x07);
//BIT 7  =  D7  PORTD 7
//BIT 8  =  D6  PORTD 6
//BIT 9  =  D5  PORTD 5
//BIT 10  = D4  PORTD 4
//BIT 11  = D3  PORTD 3
//BIT 12  = D2  PORTD 2
//  PORTD EINGÄNGE einstellen 1111 1100
DDRD &= ~(0xFC);
PORTD &= ~(0xFC);
//SS1 = A1 PORTC 1
//SS2 = A0 PORTC 0
  TCNT1=tcnt1;
  data++;
   clock = true;
  PORTC |= (1<<2); //ADC COMMAND CLOCK
  PORTC &= ~(1<<2);
    hbyte = (PINC & 0x08) | ((PINC & 0x10) >> 2) | ((PINC & 0x20) >> 4) | ((PINB & 0x04) >> 2);
    lbyte = ((PINB & 0x03) << 6) | ((PIND & 0xFC) >> 2);
    eingang = word(hbyte, lbyte);
    clock = false;
  if (data > 50000) {
    Serial.println(lbyte, BIN);
    data= 0;
the problem is that the lbyte is changing randomly and i get no fixed values.
Does anyone see any problems with the code?
I also used those analaog input pins as digital inputs... but i dont know if i have to set them to be digital or analog or what...
Damn, I dont know why the values just wont be fix...
_flo
#include <SRAM2.h>
unsigned int eingang= 0;
unsigned int out;
int bitnumber = 12;
byte lbyte;
byte hbyte;
boolean ready = true;
DDRD &= 0xF3;
//SS1 = A1 PORTC 1
//SS2 = A0 PORTC 0
DDRB |= (1<<1);
//TIMER
OCR1A =  800;       // compare A register value (167 * clock speed)
 // OCR1A =  166;
  if ((PIND & (1<<2)) == 0) {
      if (ready == false) {
        hbyte = SRAM2.RWdata(0);
        lbyte = SRAM2.RWdata(1);
        ready = true;
        data = data + 2;
      if ( data > 40000) {
        Serial.println(lbyte,BIN);
        data = 0;
    if (ready == true) {
      ready = false;
Now the ADC writes directly into the 23K256 chip. it seems to work but there is one problem.
the ADC s serial signal is 13 clock pulses the first pulse has no data value to it (the rest are the 12 bit)
Now the SRAM chip is put in sequential write mode, so these 13 clocks + the data signal should fill one and a half bytes .
the first byte is the one empty MSB and the first seven bits (given from the adc starting with the msb)
the second byte are the other 5 bits.
but when i check the high and low bytes i read from the SRAM by sending them with Serial.println
I see that the bytes are not structured like i described, because i can set every bit for the two bytes, eventhough i acutally should only be able to affect 13 of them because i ve got 13 clock pulses.
is there an obvious mistake in my code? Please give me some advice if you can!
regards,
Flo
