Audio frequency generation on AtTiny85
I'm looking for a simple way to generate audio frequencies with an AtTiny85, so it plays an continuous sound (e.g. at 440hz) when an digital Input is pulled to ground. I found an frequency generation sketch in the playground that is described as simple, it also works on an AtTiny but seems to consist mostly of floating point math. And that's a little bit too hard for me since I am a bloody beginner in audio generation :~ .
Try software DDS, essentially an array.
Didn't quite finish it here.
Say that you want to generate a 400hz sine wave. Store that information in a 256 array.
Set up a timer that trips every 1/(400*256) = 10us. In the isr, increment an accumulator and output the value in the array indexed by that accumulator.
You are done.
If you point the array to other waveforms, you can generate any waveforms as you like.
256 points are a lot for even a good quality wave form. If you want to generate faster signal, you can go to 128, 64 or even 32 points, or simply change the increment to the accumulator.
The output can be anything, a r2r network, or dac or a digital pot.
Is tone() an option? OP didn't specify a sine wave.
In the event of square waves, you can use software or hardware pwm (50 percent duty cycle).
Hardware pwm can generate signals well into the Mhz.
I want to generate pwm signal using analogwrite() in ARDUINO KIt 1.0 .I cant able to identify the pin which generates plsese help me
prash: I want to generate pwm signal using analogwrite() in ARDUINO KIt 1.0 .I cant able to identify the pin which generates plsese help me
Have you had a look at the doc? Might have something about pins there. http://arduino.cc/en/Reference/AnalogWrite
dhenry: Didn't quite finish it here.
You are done.
That sounds simple enough, is there an tutorial on this somewhere? The output is just a speaker and I want to generate a sine wave, so this seems just to be the right thing.
Introduction here -
http://interface.khm.de/index.php/lab/experiments/arduino-dds-sinewave-generator/
The sinewave is the singularly least interesting of all waveforms, the tone library will produce a far more interesting squarewave, if all you want is a tone or simple tune use the standard tone function - its what you hear in this video and sounds 100 times better than a sinewave -
DDS Can make a great sound, but its an awful lot more work than suggested, here is a simple synth that uses DDS
Not a single sinewave in sight, its all ramps and squares -
More explanation here -
Duane B
dhenry: Say that you want to generate a 400hz sine wave. Store that information in a 256 array.
You are done.
I see what you did there. Getting back to the question posed by the OP, with a specific value of 440Hz (standard concert pitch A, for tuning) rather than 400 Hz (which gives 10 ?s, albeit with a 2.4% error) you would set up a timer that trips every 8.877841 ?s.
Using the formula
compare match register = [ 16,000,000Hz/ (prescaler * desired interrupt frequency) ] - 1
with a prescaler of 1, this gives compare match register = 16,000,000 / ( 440 * 256 ) - 1 = 141.045454545454545 = 141, as an 8-bit integer. The error from integer roundoff is a pretty reasonable 0.03%. I'm not sure what the allowable error is in the 16MHz Arduino clock oscillator (pointer, anyone)?
But that looks as if it would be suitable for tuning an instrument.
The approach I outlined can generate a sine or any other waveform. You can buffer it to drive a speaker.
There is also another approach: to generate a sine wave via pwm: you will need to load the compare register with the right value to produce a desired wave form. It has the advantage of being very fast but is more difficult to program.
