Roughly speaking you want to figure out the amount of power to be dissipated (Figure 9 in datasheet gives efficiency vs output power (about 90% @ 600W implies about 60 W for continuous max output)) and the allowable temperature rise at the heat sink (call it about 60 C) which implies a heat sink rated at 1 C/W. This would be a very very serious passive heat sink.
If we're doing audio or music rather than a continuous peak signal, the amplifier average power is much less than the continuous peak power, so we can safely de-rate. Something on the order of /4 or /8 which gets to heat sink rated at 4-8 C/W which is reasonable.
Keep in mind that the TPA3255 has thermal protection, so it should not self-destruct if thermal management is insufficient, but it will distort.
Do the specs on this heatsink look right @MrMark ? It says that the heatsink has 2.2˚C/W with 1M/S air flowing across it. I would rather there be no fan at all, but would ~1foot/S be ok still?
Thermally that should be more than adequate, I haven't checked to see if it's mechanically compatible with the package.
You could have a temperature sensor controlled fan (Arduino relevance ) that only kicks in when the heat sink temperature exceeds some threshold temperature.
What is the application? Typically audio amplifiers' average power (which is what matters from a thermal standpoint) is much lower than peak power. Exceptions might include sirens or guitar amplifiers driven deep into distortion.
Haha. I am already adding an Attiny261 for IR controlling, so I could add a fan setup with that. What temp sensor could I use? The temperature can get pretty hot, so is a thermistor fine? And how would I attach it to the heatsink (not duck tape or hot glue )?
A HiFi audio system for in my house. So it definitely won't be at max power 95% of the time.
Thanks again.
