Im absolutely new to hardware, and want to get started on some projects to pass the time and make life more fun!!
In my house at the moment ive got 2 dstv decoders, a radio and cd player in my “server cabinet” and I can connect any ONE of them to the speakers in the house (50-80w car 6inch speakers) ive got like 2 in every room.
So what I want to do is give every room a arduino,remote (IR) and make every room able to choose the input and volume…..
Ive read up on audio and I am completely confused, I have no clue what preamps ect does? For the inputs can I use 4 relays? Open current selected input and just close desired input relay? how can I reduce and increase volume?
Sorry for the stupid questions but I really need some guidance
It sounds like you already have a distributed audio system, so maybe a wi-fi type connection and control would be better than infrared. If your receiver/amplifier doesn't have any type of remote control capability, there is no way sans modifying the receiver to control the volume remotely short of using a stepper motor to physically turn the control itself.
What's powering the speakers? Typically you'd already have a receiver (or preamp or integrated amp) with an input-selection switch.* And, hopefully you have an amp for each room, or a 70.7V constant-voltage system? (Connecting a bunch of speakers in parallel lowers the impedance and that can damage your amplifier, and you need separate amps if each room can select different audio sources..)
Yes. A double-pole double throw relay for each input. Or, you could also use a digitally controlled Analog Switches. (If you are going to build this thing, I'd add a couple extra inputs for unknown future requirements. )
A [u]Digital Pots[/u], assuming you are controlling line-level signals (not the speaker outputs). A digital pot won't "increase" the volume, but you shouldn't an additional gain stage.
I suggest you tackle one part at a time. I have a feeling the IR remote is the most difficult part and I'd start by turning on & off an LED (and then maybe dimming the LED).
You can also build & test the relay switching separately, and the digital-pot volume control separately. There are at least 3 different kinds of digital pot. I've never used a digital pot, but I believe there is a type that you simply feed-in an up-down pulse and that seems like the simplest to interface & "program".
It's OK to connect more than one input together.. So for example, you can use Y-Adapters (splitters) to connect the CD player output into 4 amplifiers/receivers. However, it's NOT OK to connect multiple outputs together, so you can't connect the CD-player output to the radio output. For that you need relays to select one output at a time, or a mixer to mix the audio signals.
