Audio is being heard as crackling noise wen playing from sd card module
i am running my code if anyone is up front or to the left or right using ultrasonic sensors * 2 and 1 ir sensor and when i play the respective code i am hearing crackling noise but not the sound wich is intended to b heard. But wen i tried playing the same (just for audio) it worked but nw it is nt working wen i am using tat in the code. i am using sd card module to play the music from.pls help me out
#include <SoftwareSerial.h>
#include <SD.h>
#include <TMRpcm.h>              //"to play WAV files"
#include <SPI.h>                 //"for serial peripheral interface"
TMRpcm tmrpcm;
const int chipselect = 9;
const int trig_left = 2;
const int echo_left = 3;
const int trig_right = 5;
const int echo_right = 6;    //"10 to 13 pins are used for spi protocls"
const int ir = 13;              // "miso to 12 mosi to 11 sck to 13 cs to 10 no changes must be made"
long duration_left;
long duration_right;
int distance_left;
int safe_left;
int distance_right;
int safe_right;
int ir_input;
  tmrpcm.speakerPin = 9;          //"for making pin number 9 as speaker"
  pinMode(trig_left, OUTPUT);
  pinMode(echo_left, INPUT);
  pinMode(trig_right, OUTPUT);
  pinMode(echo_right, INPUT);
  pinMode(ir, INPUT);
  pinMode(7, OUTPUT);
  digitalWrite(7,HIGH);
  if (!SD.begin(chipselect))        // "SD.begin returns if sd card readable or not"
    Serial.println("SD fail");
    return;
  tmrpcm.setVolume(6);                //"it is used to set the volume till 7 in speaker"
  digitalWrite(trig_left, LOW);
  delayMicroseconds(2);
  digitalWrite(trig_left, HIGH);
  delayMicroseconds(10);
  duration_left = pulseIn(echo_left, HIGH);
  distance_left = duration_left*0.034/2;
  safe_left = distance_left;
  if (safe_left<= 5)
    tmrpcm.play("sl.wav");
    delay(5000);
    Serial.println("left unsafe");
   delay(100);
  digitalWrite(trig_right, LOW);
  digitalWrite(trig_right, HIGH);
  duration_right = pulseIn(echo_right, HIGH);
  distance_right = duration_right*0.034/2;
  safe_right = distance_right;
  if (safe_right<= 5)
    tmrpcm.play("sr.wav");
    delay(5000);
    Serial.println("right unsafe");
  delay(100);
  ir_input = digitalRead(ir);
  if (ir_input== HIGH)
    tmrpcm.play("sf.play");
    delay(5000);
Sorry where is the question in your paragraph?
Describe environment, goal, code, set-up and issue, what you have tried etc
