Audio Multiplexer advice
Seeking advice on the selection of an audio multiplexer to enable an output of multiple microphones to be selected. I've been investigating some analog multiplexers available but wonder if there is an IC more suitable to audio. Thanks - Scotty
It is probably best if you amplify the signals before you multiplex them so they the signal to noise ratio is minimised.
Thanks for the advice Grumpy Mike. Good to know to avoid starting off on a wrong path. - Scotty
