Audio Playback Not Working w/Joystick
I've built a model of an ancient temple (think Indiana Jones) that has a rolling door that opens or closes based on the direction of the joystick. I would like to add a sound effect of a stone door rolling but I'm having trouble incorporating this sound effect into my model when using the joystick (perhaps because I'm using a While statement. When I add the DoorRoll.wav to my joystick operation the door refuses to open and the SFX hang the program. Other SFX work when various buttons are pushed so I know it's a coding issue.
I'm using an Arduino Mega with the tmrpcm library. The sound effects are tested and work in other configurations but I cannot attach this sound effect to the action of the joystick with success. Any thoughts would be appreciated.
As I said, are other elements on the model but, to keep this post simple, I have whittled down the code to just include what's necessary for the door to operate but I'm also attaching the complete code for the other functions of the model (Buttons, LED's, LCD screen, etc.) if you want to see the full code.
#include <Stepper.h>          //Stepper Library
#include <SD.h>               //SD Card Library
#include <TMRpcm.h>           //Speaker Library
String sketchName = "Temple Exhibit";
String sketchVersion = "3.00";
// 28BYJ48 with ULN2003 driver pins
#define STEPS 32  //default value 32
#define IN1 8
#define IN2 9
#define IN3 10
#define IN4 11
Stepper templeStepper(STEPS, IN1, IN3, IN2, IN4);
// Audio
TMRpcm tmrpcm;            //creating an audio player object
//joystick pins
const int joyXPin = A0;
const int joyYPin = A1;
const int joyButtonPin = 48;
//stepper limit switches
const int limitSwitch0Pin = 20; // closed limit
const int limitSwitch1Pin = 21; // open limit
volatile int limitSwitch0State;
volatile int limitSwitch1State;
//other pins
const int tree1Pin = 37;              //Model's Indicator LED
const int lavaPin = 38;               //Trench fire LED
const int cavePin = 39;               //Cave Torch Fire LED (x3)
int doorState;    //Is door open or closed
int joyXVal;
int joyYVal;
int joyButtonVal;
int dt = 10;                        // delay time
int mdt = 100;                      // delay time-medium
int ldt = 1000;                     // delay time-long
  Serial.println(sketchName);         //Report Sketch version
  Serial.println(sketchVersion);
  tmrpcm.speakerPin = 12;             //The speaker is connected to 12 Pin. You can use any PWM Pin.
  tmrpcm.setVolume(4);                //to adjust the speaker volume; 4 = max for current speaker
  pinMode(limitSwitch0Pin, INPUT_PULLUP);  //home pin (door closed)
  pinMode(limitSwitch1Pin, INPUT_PULLUP);  //stop pin (door opened)
  pinMode(joyXPin, INPUT);
  pinMode(joyYPin, INPUT);
  pinMode(joyButtonPin, INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(limitSwitch0Pin), stopMotor0, FALLING);
  attachInterrupt(digitalPinToInterrupt(limitSwitch1Pin), stopMotor1, FALLING);;
  // TEMPLE DOOR HOMING******************************************************
  delay(dt);
  lcd.clear();                               //clear screen
  lcd.setCursor(0, 0);
  lcd.print("<<DOOR RESETTING");
  lcd.setCursor(0, 1);
  lcd.print(" Homing Protocol");
  delay(dt);
  limitSwitch0State = digitalRead(limitSwitch0Pin);
  while (limitSwitch0State == HIGH)
    templeStepper.setSpeed(250);           // code to move one step towards the switch
    templeStepper.step(1);                 //Set rotation direction to CW
  }  //end while, motor is now at HOME position
  doorState = 0; //door is now closed
  delay(dt);
  lcd.clear();
  lcd.print("  DOOR RESET");
  lcd.print("Homing Complete ");
  Serial.println("Homing Complete");
  Serial.println("");
  delay(ldt);
  //Speaker Check************************************************************
  if (!SD.begin(53))                    //If the card is available.
    lcd.clear();                        //Set LCD to default screen
    lcd.print(" SD CARD READER ");
    lcd.print("      FAIL      ");
    Serial.println("SD fail");            //Write in the serial port "SD fail".
    return;
  tmrpcm.play("LampKey1.wav");          //Play startup music cue
  delay(mdt);
}  //End Setup************************************************************
  joyXVal = analogRead(joyXPin); // read and store X value
  joyYVal = analogRead(joyYPin); // read and store Y value
  joyButtonVal = digitalRead(joyButtonPin); // read and store button value
  if ((joyXVal > 500) && (joyXVal < 525)) //If joystick is neutral turn off stepper motor
    digitalWrite(IN1, LOW);
    digitalWrite(IN2, LOW);
    digitalWrite(IN3, LOW);
    digitalWrite(IN4, LOW);
    delay(dt);
    while ((joyXVal >= 525) && (doorState == 0))  //While doorState is closed and joystick is pushed RIGHT
      templeStepper.setSpeed(900);
      templeStepper.step(-1);                     //Set rotation direction to CCW
  while ((joyXVal <= 495) && (doorState == 1)) //While joystick is pushed LEFT
  delay(dt);
  Serial.print("Joystick x,y = (");
  Serial.print(joyXVal);
  Serial.print(" , ");
  Serial.print(joyYVal);
  Serial.println(")");
} //End Void Loop*********************************************************
void stopMotor0() {
  doorState = 0;    //door is closed
  Serial.println("Door is closed");
void stopMotor1() {
  doorState = 1;    //door is open
  Serial.println("Door is open");
Temple_Exhibit_3.00.ino (17.5 KB)
Nice pictures! I would start by getting rid of the delay statement and use the millis function. Try replacing the While with if then else type of code. That should get you going and the stone grumbling!
Yes, use if's, not whiles, and draw out a state-transition diagram - you should only need to add some
"start sound-effect" and "stop sound_effect" actions in the relevant places.
