Audio Sample Player
Hi all
Having some trouble with this art project called “The macePod”. Audio samples should play on demand (cf. sample machine). As test I tried the sketch below where the samples are played for 2 secs.
It works more or less: I have some strange vibrations in my playback. After a while the files start playing like in tremolo.
Another thing is a lot of noise…
  DUE - SD card WAV player 3
 The circuit: use 6-pin SPI connector
  Uno 10  CS   SS     Due  10
      11  DI   MOSI        ICSP-4
      12  DO   MISO        ICSP-1
      13  CLK  SCK         ICSP-3
// include the SD library:
#include <SPI.h>
#include <SD.h>
#include <Audio.h>
#include <Timer.h>
// set up variables using the SD utility library functions:
Sd2Card card;
SdVolume volume;
SdFile root;
Timer t;
File myFile;
const int chipSelect = 10;
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.print("\nInitializing SD card...");
  pinMode(SS, OUTPUT);
  while (!card.init(SPI_HALF_SPEED, chipSelect)) {
    Serial.println("initialization failed....");
  if (!SD.begin(chipSelect)) {
    Serial.println(" Failed!");
    return;
  Serial.println(" OK.");
  // 44100kHz stereo => 88200 sample rate
  // 100 mSec of prebuffering.
  SPI.setClockDivider(4);
  Audio.begin(88200, 100);
  int sPRF = 1;
  int sBNK = 1;
  int sTRK = 1;
  int OK;
  OK = macePod(sPRF, sBNK, sTRK, 2000, 0, 512);
  Serial.print("\n*** macePod "); Serial.println(OK);
int macePod(int PRF, int BNK, int TRK, int duration, int pitch, int vol) {
  char sampleFile[20];
  const int S = 1024; // Number of samples to read in block
  short buffer[S];
  int volume = vol;
  for (int track = 1; track <= 4; track++) {
    sprintf(sampleFile, "%d-%d-%d.wav", PRF, BNK, track);
    Serial.print("["); Serial.print(track); Serial.print("] ");
    // open wave file from sdcard
    myFile = SD.open(sampleFile, FILE_READ);
    if (!myFile) {
      return 1;
    int count = 0;
    while (count <= duration/10) {
      // read from the file into buffer
      myFile.read(buffer, sizeof(buffer));
      // Prepare samples
      Audio.prepare(buffer, S, volume);
      // Feed samples to audio
      Audio.write(buffer, S);
     count++;
    myFile.close();
    //Serial.println("End of file. Thank you for listening!");
    // while (true) ;
  return 0;
Changed the sketch so it skips to the next track with a button. Same problem: I get “tremolo” (vibrating) sound after some tracks…
DUE - SD card WAV player BUTTON
Uno 10 CS SS Due 10
11 DI MOSI ICSP-4
12 DO MISO ICSP-1
13 CLK SCK ICSP-3
#include <SPI.h>
#include <SD.h>
#include <Audio.h>
Sd2Card card;
File myFile;
const int btnPin = A2;
const int ledPin = A3;
int trkSel = 1;
int buttonState = LOW;
pinMode(btnPin, INPUT);
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, LOW);
Serial.print("\nInitializing SD card…");
// we’ll use the initialization code from the utility libraries
// since we’re just testing if the card is working!
Serial.println(“initialization failed…”);
return;
// SPI.setClockDivider(4);
  int sPRF = 1;
  int sBNK = 1;
  int sTRK = 1;
  int OK;
  buttonState = digitalRead(btnPin);
  if (buttonState == HIGH)
    OK = macePod(sPRF, sBNK, trkSel, 1500, 0, 512);
    trkSel++;
    if (trkSel > 4 ) {
      trkSel = 1;
  short buffer[S] = {};
  int volume = vol;
  //  for (int track = 1; track <= 4; track++) {
  sprintf(sampleFile, "%d-%d-%d.wav", PRF, BNK, TRK);
  Serial.print("[Sample "); Serial.print(TRK); Serial.print("] ");
  myFile = SD.open(sampleFile);
  if (!myFile) {
    return 1;
    int count = 0;
  // Prepare samples
    count++;
  myFile.close();
  return 0;
The format of the filenames is: 1-1-1.wav, 1-1-2.wav etc ...
