I'm trying to figure out a code which will output a pulse wave from an ATtiny84/85, the pulse wave needs to be controllable from around 33khz to around 100hz.
I will use this oscillator to control a switch in an analog audio circuit to create a ring modulator/sample rate reducer style effect.
Is there a way to control a PWM pin to output frequenciess that broad and being controllable with a pot?
No 100hz, im essentially using this oscillator as a carrier frequency to turn on and off a switch that passes audio, creating a ring modulator/sample rate reducer sort of effect.
I don't think the ATtiny has enough processing power or memory for audio DSP and there is no DAC (no true-analog output).
You don't really want PWM. Regular digital audio is PCM.
With the right processing you could modulate the sample rate, but I assume that would be done temporarily/internally in a buffer so the input & output has a normal-constant sample rate.
My plan wasn't to do DSP or convert audio into digital in anyway.
All i planned on doing was generate a pulse wave oscillator which i could control with a pot, spanning frequencies above human hearing (ideally around 30+khz, and being as low as 100hz), i will use this oscillator to turn on and off an analog circuit which will pass audio, creating a ring mod/sample rate reduction effect.
33kHz should be doable with a Tiny85 and Direct Digital Synthesis and you should get at least 10Hz resolution. I'm pretty sure I was able to do 44kHz that way, but it's been a while. Check out the Arduino DDS library.
[edit]
You will need the external 16MHz crystal on the Tiny85, to be clear. It probably won't work with the internal 1MHz clock.
