I am trying to make an arpeggiator guitar with membrane potentiometers, but the signal freezes every few notes. The signal freezes only while switching between notes, and the frozen signal is either 5V or 0V. The arpeggiation continues while the signal is frozen, the notes are simply skipped.
For example, if I have notes A, B, C, and D that arpeggiate like so:
A B C D A B C D A B C D
The signal will only output something like:
A _ _ _ A B ‾ ‾ ‾ ‾ C D
I am currently using an Arduino Micro with Timer 0 running at 100,000 Hz and Timer 1 running at 10 Hz.
I have tried:
- Changing power supplies
- Running with no load (only an oscilloscope)
- Changing the output pin
- Changing period[] to constant values instead of calculating them from potentiometers
- Removing all IO pins except for the output
- Removing all modes except for the simplest one - legato
- Clearing loop()
- Removing Timer1 entirely and using _delay_ms() to change the 'string' in loop()
I am at a loss at what to do. Here is the condensed code (that still has the issue):
pinMode(11,OUTPUT);
cli();
// Timer 0: 100,000 Hz
TCCR0B = (1 << CS01); // /8
TCCR0A = (1 << WGM01);
OCR0A = 19; // 16000000/(8*100000) - 1 = 19
TIMSK0 = (1 << OCIE0A);
// Timer 1: 10 Hz
// TCCR1B = (1 << CS11) | (1 << CS10);
// TCCR1B |= (1 << WGM12);
// TCCR1A = 0x00;
// OCR1A = 24999;
// TIMSK1 |= (1 << OCIE1A);
sei();
int period[4] = {271, 203, 362, 113};
int t = 0;
int current_string = 0;
int m = 0;
ISR(TIMER0_COMPA_vect) {
t++;
if (t==period[current_string]) {
m = !m;
t=0;
PORTB = (m << 7) | (PORTB & 0b01111111);
// ISR(TIMER1_COMPA_vect) {
// if (current_string == 3) {
// current_string = 0;
// } else {
// current_string++;
current_string = 0;
current_string++;
_delay_ms(100);
