// Using:
// * 32x16-LED DMD
#define LIN_OUT 1
#define FHT_N 128 // set to 256 point fht 128
#include <FHT.h> // include the library
#include <SPI.h>
#include <DMD.h> //
#include <TimerOne.h> //
#include "SystemFont5x7.h"
#include "Arial_black_16.h"
#define DISPLAYS_ACROSS 1
#define DISPLAYS_DOWN 1
DMD dmd(DISPLAYS_ACROSS, DISPLAYS_DOWN);
// Change this to MONO to for a one-channel full-display or STEREO for two-channel
String displayType = "MONO";
byte sampleR[64]; //64
byte sampleL[64];
unsigned long startTime, endTime, oldTime;
String displayText = "DY";
String sampleSet;
int displaySize;
void ScanDMD()
dmd.scanDisplayBySPI();
if (displayType == "MONO") {displaySize = 32;} else {displaySize = 16;}
//TIMSK0 = 0; // turn off timer0 for lower jitter
ADCSRA = 0xe7; // set the adc to free running mode
ADMUX = 0x45; // use adc5
DIDR0 = 0x20; // turn off the digital input for adc5
Timer1.initialize( 5000 ); //period in microseconds to call ScanDMD. Anything longer than 5000 (5ms) and you can see flicker.
Timer1.attachInterrupt( ScanDMD ); //attach the Timer1 interrupt to ScanDMD which goes to dmd.scanDisplayBySPI()
dmd.clearScreen( true ); //true is normal (all pixels off), false is negative (all pixels on)
dmd.selectFont(Arial_Black_16); // show off who wrote the app... :p
dmd.drawString(6,1,"DY",2,GRAPHICS_NORMAL);
delay(3000);
dmd.drawString(6,1,"CJ",2,GRAPHICS_NORMAL);
delay(3000);
dmd.selectFont(SystemFont5x7);
dmd.drawString(2,0,"Audio",5,GRAPHICS_NORMAL);
dmd.drawString(2,9,"Analy",5,GRAPHICS_NORMAL);
delay(3000);
startTime = millis();
sampleSet = "L";
sampleInput();
sampleFix();
if (displaySize == 16) {
sampleSet = "R";
sampleInput();
sampleFix();
drawSpectrum();
endTime = millis();
void drawSpectrum () {
dmd.clearScreen(true);
for (int disX; disX < 16; disX++) {
dmd.drawLine (disX, 16, disX, 16-sampleL[disX+1], GRAPHICS_NORMAL );
dmd.drawLine (17+disX, 16, 17+disX, 16-sampleR[disX+1], GRAPHICS_NORMAL );
else {
for (int disX; disX < 33; disX++) {
void sampleInput() {
cli(); // UDRE interrupt slows this way down on arduino1.0
for (int x=0; x<FHT_N; x++) {
while(!(ADCSRA & 0x10)); // wait for adc to be ready
ADCSRA = 0xf5; // restart adc
if (sampleSet == "L") {
ADMUX = 0x44; // use adc4
byte m = ADCL; // fetch adc data
byte j = ADCH;
int k = (j << 8) | m; // form into an int 8
k -= 0x0200; // form into a signed int
k <<= 6; // form into a 16b signed int 6
fht_input[x] = k; // put real data into bins
sei();
fht_window(); // window the data for better frequency response
fht_reorder(); // reorder the data before doing the fht
fht_run(); // process the data in the fht
fht_mag_lin();
void sampleFix() {
int newPos;
float fhtCount, tempY;
for (int x=0; x < displaySize; x++) {
fhtCount = FHT_N/2; // 2
newPos = x * (fhtCount / displaySize); // single channel half-display 15-LED wide
tempY = fht_lin_out[newPos];
sampleL[x] = ((tempY/256)*16); // single channel full 16 LED high
sampleR[x] = ((tempY/256)*16); // single channel full 16 LED high
