Audio Transmission
Similar applications with ham radios feed the attenuated signal into the mic input after it has been attenuated. I'd try dividing your audio signal down to a low level with a potentiometer.
PMR446. Analogous to the US FRS radios.
You could try "audio coupling" - put the speaker up to the microphone, adjust the speaker volume as necessary.
Actually, all the type of transceivers you are thinking about have a fixed number of defined frequencies and you will have to accept any interference you find on your choice of frequency.
Roger that, looking into it, appreciated!
Thanks,
Do you meanconnect the speaker out connection to the mic in connection? Or physically put the speaker next to the microphone?
Maybe I worded that incorrectly. What I meant was transmit on a frequency that the transceiver can pick up. Have the transmission frequency adjustable depending on the area/frequencies in use/legality.
FYI, a handheld radio might need an input of around 20 mV peak to peak at the mic input so be aware.
You can also normally use a logic level MOSFET to switch the push to talk of your radio rather than a relay.
Please do some research relating to your own area. All the potential devices/frequencies in the US that are license-free specifically prohibit data transmission, which is what you are asking about.
It turns out that @english_fellow is in the UK. Who knew, right? :grinning:
There is a service there called PMR446 that is roughly equivalent to the US FRS/GMRS. It is sort of compatible with its European counterpart with the notable exception that they allow digital as well as analog transmission. What I don't know is if they allow remote control of a transmitter and @english_fellow will have to determine that if they want to be strictly legal.
Thanks again, and its possible to connect the audio out to the mic in directly if I divide the audio signal down to below the mic input? Would that give the same signal as speaking into the microphone?
Will for sure use a MOSFET as the switch eventually.
Yes, you would capacitively couple the signal as well as attenuating it. Your audio source might have a capacitor on the output already but if not, add one. Depending on the input impedance of the mic input a 1 microfarad cap would be a good choice.
Fantastic, thanks again for the advie =]
