Audio Transmitter and Receiver with 433Mhz RF Modules
Hi everybody,
Anybody please tell me, Can we Transmit and Receive Voice from these 433Mhz RF Link.?
433Mhz RF Link!
If 'YES' please tell me from where i should start.
Thank you very much
Transfer rate: 4KB / S
I suspect that should say 4kb / s, so I'd say, no, you can't do voice.
Using XBees.?
The TMRh20 is an awesome set of libraries. Even for audio: GitHub - nRF24/RF24Audio: Arduino library for streaming data/audio from analog inputs via NRF24L01 modules
The 433MHz modules are probably not good at 4kbps. They are more 2kbps. Due to legal restrictions, they may be active only 1/10 of the time. That is 200bps. That is 25 bytes per second, and let's assume 5 bytes overhead. The final result is 20 bytes per second.
THanks Koepel I'll look into that. :slight_smile:
For the cost of an Arduino and radio module, you could by a Baofeng handheld.
Finally reviving this thread!
Technically: YES!
And I did it, because I want to build a very very crude and simple walkie talkie.
The idea is to modulate the voice to a variable PWM signal, like it's done in class-D amplifiers.
This PWM signal is a digital signal we can now transfer using those generic 433MHz modules.
Obivously because of the low transfer rate, we can only use a modulating frequency of (I tested and found working) around 10kHz. Therefore the audio quality is bad, but certainly enough for voice.
With 10kHz, I even got a range of more then 100m!
