I have been making a Google Glass with arduino and i have been wondering about turning your arduino into a augmented reality machine. I have serched for this but all I can seem to find is using your arduino and computer to make augmented reality.If a iphone or ipad can make augmented reality i don't know why a arduino cannot, essentially you can do everything that iphone douse with a arduino. if anybody has any ideas please comment or a link to a page witch has some helpful information.
You're absolutely right, if you ignore one of the dimensions of the problem - time.
Somewhere on the web (here) there's an article about someone who wrote an ARM emulator for the AVR, and managed to boot a Linux image from SD card.
I think from power-on to login prompt was something like two hours (And that was a serial driven command line, not a graphical one)
You may want to tell us what you mean by "Augmented Reality" - because that term can cover a lot.
At it smallest - an LED (or a small LED array) could be reflected into the eye via a half-silvered mirror or prism, to give a very basic display; one dot (maybe multi-colored), or many-dots (forming small patterns). This tiny "display" would "augment" the "reality" you would see around you through/around the display mirror/prism.
This could be expanded further with a small dot-matrix LCD display - again, reflected in some manner into the eye. This would allow longer messages, and simple graphics.
Next would be a color LCD display - slightly higher resolution; something like this would be at the limit an Arduino could comfortably drive (likely via SPI).
That wouldn't include any sensing, processing, or storage; depending on what you want your augmented reality display to do - only a little to maybe some of the processing could be done by the Arduino; the rest would have to come from somewhere else.
For instance - if you had your Arduino connected via Bluetooth to your phone, and the phone could send commands to tell the display what to do - while leaving all the heavy lifting (sensors, data, storage, etc) to the phone - and the display was fairly basic - then yes, your Arduino could in some small manner be used for a portion of the augmented reality system.
On the other hand - if you are expecting the Arduino to have full 3D graphic overlays with texturing at 100+ frames-per-second - that is not going to happen; you would need to find another platform to give you that capability.
So - what is it you expect or want the Arduino to do in your system?
cr0sh:
I was thinking of displaying a 3d image from augmented reality on a oled screen , you said how this is impossible, how could i make this maybe not with the arduino?
1234567891012151617:
can everyone stop saying how stupid I am and start suggesting ways to do augmented reality on arduiunos ( mega , uno , micro or otherwise ).
I believe the responses have indicated that the arduinos you mentioned lack the processing power and memory to handle video, which requires a very high clock frequency and plenty of memory. iPhones come with a minium of 16Gb. How many arduinos come with 16Gb ? Do you see why your request is prompting the responses you are getting ? (like "you're kidding ?"
1234567891012151617, can you please answer post #10.
This because we have no idea of your knowledge level.
This will help us explain why the arduino is not suitable for your project.
TomGeorge:
Thanks.. Tom.....
I am realy just starting out I was wandering if this project could be done. so i would not waste my time
This is not a 'just starting out' project on any platform. I suggest you seek out some of the beginning tutorials and go from there. They may seem simplistic but there is a world of difference between watching a video, reading a tutorial, whatever and actually starting do design and build circuits.
I've watched people run marathons on TV so I should be able to run one, right? This is actually NOT an over simplification. Both take a lot of prep work.
outofoptions:
