Context:
I have 3 flats and 2 farm houses. I want to track the electricity consumption and turn on/off at will using my mobile(Azure portal).
I am an Azure Programmer and designed few reports by myself. I want Arduino based hardware which can feed electricity consumption live data to these Azure reports using this Arduino hardware. Also, I would like to send commands from Azure program to the Arduino hardware and turn on/off the power connection at the electricity meter.
Needs
- I need to have an Arduino based hub which will be connected to internet at my router and can feed data to my Azure program.
- A z-wave controller need to be installed at the electricity meter to read the consumption and send the live data to my azure program through the installed hub.
- Electricity meter emits the reading using an IR blaster
- Z wave controller need to have IR receiver to read this data.
- Z wave controller at the meter should be able to receive the commands from the hub to turn on/off power connection
- Z wave controller should run on the power derived from the line at meter.
- Hub should have provision to register/de-register z wave electricity meter device.
- Hub should be extendible to accept more z wave controller device registrations such as existing z wave devices in the market to control lights, fans e.t.c
- Hub should be of 2 types.
a. USB version to plug in to an existing internet router. It should be able to derive the power and internet from the router
b. A standalone version with inbuild GSM slot to insert SIM card for internet and power supply. - Hub should have a configuration interface to facilitate connecting to a local network and to my azure program using a unique ID
Instead of Arduino based hardware, If you want to offer a better solution using a micro controller based approach to facilitate data feed to azure, I am open for ideas.
