aurduino duo with eth shield loading wav files using TMRpcm
hi there working on a project were the program loads wav files for the sd card when a button is pressed loaded the lib in ect code wont run. anyone see anything wrong with my code that im missing. had a good old look around the forums for similar problems.
#include "SD.h" //Lib to read SD card
#include "TMRpcm.h" //Lib to play auido
#include "SPI.h" //SPI lib for SD card
#define SD_ChipSelectPin 13 //Chip select is pin number 13
TMRpcm audio; //Lib object is named "audio"
int wheel = 2;
int button = 4;
int lever1 = 7;
int lever2 = 8;
int led1 = 14;
int led2 = 15;
int led3 = 16;
int led4 = 17;
int led5 = 18;
audio.speakerPin = 9; //Auido out on pin 9
Serial.begin(9600); //Serial Com for debugging
if (!SD.begin(SD_ChipSelectPin)) {
Serial.println("SD fail");
return;
pinMode(wheel, INPUT_PULLUP); //Button 1 with internal pull up WHEEL
pinMode(button, INPUT_PULLUP); //Button 2 with internal pull up BUTTON
pinMode(lever1, INPUT_PULLUP); //Button 3 with internal pull LEVER 1
pinMode(lever2, INPUT_PULLUP); //button 4 WITH PULL UP LEVER2
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
pinMode(led4, OUTPUT);
pinMode(led5, OUTPUT);
audio.setVolume(5); // 0 to 7. Set volume level
audio.quality(0); // Set 1 for 2x oversampling Set 0 for normal
//audio.volume(0); // 1(up) or 0(down) to control volume
//audio.play("filename",30); plays a file
if (digitalRead(wheel) == HIGH); //WHEEL IS ROTATED
audio.play("wheel.wav"); //Play WHEEL
digitalWrite(led1, HIGH); //light led1
{ if (digitalRead(button) == LOW); //WHEEL IS NOT ROTATED
digitalWrite(led2, LOW); //led off
if (digitalRead(button) == HIGH); //Button 2 Pressed
audio.play("button.wav"); //Play BUTTON
digitalWrite(led2, HIGH); // led on
{ if (digitalRead(button) == LOW); //Button 2 NOTPressed
digitalWrite(led2, LOW); // led off
if (digitalRead(lever1) == HIGH); //LEVER 1 IS SWICHED
audio.play("lever1.wav"); //Play LEVER1
digitalWrite(led3, HIGH);//led on
{ if (digitalRead(lever1) == LOW); //LEVER 1 IS NOT SWICHED
digitalWrite(led3, LOW);//led off
if (digitalRead(lever2) == HIGH) //LEVER 2 IS SWICHED
audio.play("lever2.wav"); //Play LEVER2
digitalWrite(led4, HIGH);//led on
{ if (digitalRead(lever2) == LOW); //LEVER 2 IS NOT SWICHED
digitalWrite(led4, LOW); // led off
if (digitalRead(wheel), (button), (lever1), (lever2) == HIGH); //EVERYTHING IS PRESENT
audio.play("fanfare.wav"); //Play FANFARE
digitalWrite(led5, HIGH); //led on
F:\VENDOR\VENDOR.ino:78:42: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
and lots of
VENDOR:96:17: error: expected '}' at end of input
at the end
any ideas? :o
It is unusual to see a properly written if statement end with a semicolon.
It is unusual to see properly written code with two open curly braces in a row.
Sort out the useless curly braces from the necessary ones, and you'll see what the problem is.
Code NEVER follows a { on the same line.
yeah looks like alot, ive removed them still has the same error C:\Users\mark\Desktop\sketch_apr18a\sketch_apr18a.ino:44:27: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
{audio.play("wheel.wav");} //Play WHEEL
still seems like the TMRpcm library doesn't like my syntax, anyone got this working?
Try this:
audio.play((char *)"wheel.wav");
nice work paul, that sorted it out. is karma good :slight_smile: still got another error I'm sure it's just some sort of punctuation
error: expected constructor, destructor, or type conversion before '(' token
pinMode(wheel,INPUT_PULLUP); //Button 1 with internal pull up WHEEL
eyes are crossing together now reading searches. not sure if i could do it differently :o
error: expected constructor, destructor, or type conversion before ‘(’ token
When the line being referenced looks correct, look before that line, to see if there is a problem with that line.
The line before the one that the compiler complained about is the curly brace that ends setup(). You can’t make function calls outside of a function.
int wheel = 2;
int button = 4;
int lever1 = 7;
int lever2 = 8;
int led1 = 14;
int led2 = 15;
int led3 = 16;
int led4 = 17;
int led5 = 18;
return;
pinMode(button,INPUT); //Button 2 with internal pull up BUTTON
pinMode(lever1,INPUT); //Button 3 with internal pull LEVER 1
pinMode(lever2,INPUT); //button 4 WITH PULL UP LEVER2
pinMode(led1,OUTPUT); //led1
pinMode(led2,OUTPUT); //led2
pinMode(led3,OUTPUT); //led3
pinMode(led4,OUTPUT);
pinMode(led5,OUTPUT);
audio.quality(1); // Set 1 for 2x oversampling Set 0 for normal
if (digitalRead(wheel) == HIGH) //WHEEL IS ROTATED
audio.play((char *)"wheel.wav"); //Play WHEEL
if (digitalRead(button) == LOW) //WHEEL IS NOT ROTATED
if (digitalRead(button) == HIGH) //Button 2 Pressed
audio.play((char *)"button.wav"); //Play BUTTON
if (digitalRead(button) == LOW) //Button 2 NOTPressed
if (digitalRead(lever1) == HIGH) //LEVER 1 IS SWICHED
audio.play((char *)"lever1.wav"); //Play LEVER1
if (digitalRead(lever1) == LOW) //LEVER 1 IS NOT SWICHED
audio.play((char *)"lever2.wav"); //Play LEVER2
if (digitalRead(lever2) == LOW) //LEVER 2 IS NOT SWICHED
if (digitalRead(wheel), (button), (lever1), (lever2) == HIGH) //EVERYTHING IS PRESENT
audio.play((char *)"wheel.wav"); //Play FANFARE
C:\Users\mark\Desktop\VENDOR\VENDOR.ino: In function 'void loop()':
C:\Users\mark\Desktop\VENDOR\VENDOR.ino:45:28: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
C:\Users\mark\Desktop\VENDOR\VENDOR.ino:58:34: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
C:\Users\mark\Desktop\VENDOR\VENDOR.ino:68:38: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
C:\Users\mark\Desktop\VENDOR\VENDOR.ino:78:42: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
C:\Users\mark\Desktop\VENDOR\VENDOR.ino:90:45: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
exit status 1
thats the full thing again, many thanks for helping Paul cant beleve im still awake.
    return;
That is your setup() function. It looks like you failed to use curly braces after the if statement. It looks like you are clueless about what the return is going to accomplish.
You STILL have a lot of code between the end of setup() and the start of loop(). That is STILL not allowed.
