auto acknowledge failed with nrf24L01+ and arduino uno
my transceivers are running fine. i 've written a few code and got them running.then i decided to check the auto acknowledgement feature wherein we can return data back to the sender WITHOUT manually changing the radio modes on both units.but i find that the serial monitor always shows “failed to transmit”.why is this happening cause otherwise they work fine.
it is a very simple code that just transmits integers.
i am using maniacbug’s RF24master library.
the Tx code is-
#include<SPI.h>
#include<nRF24L01.h>
#include<RF24.h>
int msg[1] = {1};
int rec[1] = {0};
bool stat = true;
RF24 radio(9,10);
const uint64_t pipe[1] = {0xF0F0F0F0E1LL};
  Serial.begin(57600);
  radio.begin();
  radio.setAutoAck(true);
  radio.enableAckPayload();
  radio.openWritingPipe(pipe[0]);
  radio.setRetries(15,15);
  if(stat)
    radio.stopListening();
    bool ok = radio.write(msg,sizeof(msg));
    delay(100);
    if(ok)
    {Serial.println("transmitted successfully !!");}
    {Serial.println("faileed to transmit");}
    msg[1]++;
    if(msg[1]>=200)
    {msg[1]=1;}
    stat = false;
    //delay(20);
  if(!stat)
    if(radio.isAckPayloadAvailable())
      radio.read(rec,sizeof(rec));
      Serial.print("received ack payload is : ");
      Serial.println(rec[1]);
      stat = true;
and the Rx part is -
#include<SPI.h>
#include<RF24.h>
const uint64_t pipe = 0xF0F0F0F0E1LL;
RF24 radio(9,10);
int rec[1] = {0};
int ack[1] = {1};
  radio.begin();
  delay(100);
  radio.openReadingPipe(1,pipe);
  radio.startListening();
  if(radio.available())
    Serial.println("payload available....");
    bool ok = radio.read(rec,sizeof(rec));
    if(ok)
        Serial.println("message received !!");
        Serial.print("integer got is : ");
        radio.writeAckPayload(1,ack,sizeof(ack));
    {Serial.println("failed to receive the message");}
well my previous tx code had a lot of bugs. i fixed them and the auto ack is happening but there is this new observation i made:
first of all my tx code is:
#include<SPI.h>
#include<RF24.h>
int msg[1] = {1};
int rec[1] = {5};
bool stat = true;
bool ok;
RF24 radio(9,10);
  radio.begin();
  //radio.setDataRate(RF24_250KBPS);
  radio.enableDynamicPayloads();
  //radio.stopListening();
  if(stat)
    Serial.println("enteed the if loop");
    if(radio.write(msg,sizeof(msg)))
        Serial.println(rec[0]);
        stat = false; //doing this completely shuts down the transmitter if an ack payload is not received !!
        Serial.println("status has become false so stop here....");
      msg[0]+=3;;
    if(msg[0]>=100)
    {msg[0]=1;}
    //delay(100);
and the rx code is(minor changes):
#include<SPI.h>
#include<RF24.h>
const uint64_t pipe[1]= {0xF0F0F0F0E1LL};
RF24 radio(9,10);
int rec[1] = {0};
int ack[1] = {990};
  radio.begin();
  delay(100);
  //radio.enableDynamicPayloads();
  radio.openReadingPipe(1,pipe[0]);
    if(radio.read(rec,sizeof(rec)))
  /*else
  {Serial.println("payload not available");}*/
THE OBSERVATION :
the tx serial monitor shows this–
enteed the if loop
faileed to transmit
enteed the if loop
received ack payload is : 990
enteed the if loop
faileed to transmit
enteed the if loop
enteed the if loop
faileed to transmit
enteed the if loop
enteed the if loop
faileed to transmit
enteed the if loop
enteed the if loop
faileed to transmit
enteed the if loop
enteed the if loop
faileed to transmit
enteed the if loop
enteed the if loop
faileed to transmit
enteed the if loop
enteed the if loop
faileed to transmit
enteed the if loop
enteed the if loop
faileed to transmit
enteed the if loop
enteed the if loop
faileed to transmit
enteed the if loop
enteed the if loop
faileed to transmit
enteed the if loop
enteed the if loop
faileed to transmit
enteed the if loop
enteed the if loop
faileed to transmit
enteed the if loop
enteed the if loop
faileed to transmit
enteed the if loop
enteed the if loop
faileed to transmit
enteed the if loop
enteed the if loop
why is it alternating??why is it not able to transmit properly after a previous transmit??
please comment
finally a detailed solution and a video can be found -
http://wp.me/p4Mna0-3a
http://wp.me/p4Mna0-32
http://youtu.be/MOMZrCw6ql8
shantam: why is it alternating??why is it not able to transmit properly after a previous transmit?? please comment
Did you figure out the exact reason why every other transmit failed? I ran into something a bit similar myself, except that if i tried to send the same data more than once I never got an ack after the first one... changing the data, and everything was fine. I'm not using data in ack, just a plain ack.
I somehow got rid of this bug I had, but I've seen it come and go, so would rather be prepared next time it arrives.
