Auto changing the range output variable, from mA to A for example
Hi, I'm making an Inductance meter and I want to automatically convert the output variable, in this case uH to mH, whenever the output surpases the 1E-6 to 1E-3 limit, everything else in the prog is fine, it's an old project from the internet, but in the original they show the same reading at the same time in two different ranges, and I would like to improve that since I have an 0,96" Oled display,wich is super tiny....
Best regards from Cuba and excuse my English...
pcarlos683:
Please post the code you currently have/using
Please post the current code but Read this before posting a programming question first
Sorry about that, haven't read that :slight_smile:
#include<Wire.h>
#include<Adafruit_GFX.h>
#include<Adafruit_SSD1306.h>
double pulse,frequency, inductance;
double capacitance=2.43E-6;
#define ANCHO 128
#define ALTO 64
#define OLED_RESET 4
Adafruit_SSD1306 oled(ANCHO,ALTO,&Wire,OLED_RESET);
pinMode(11,INPUT);//entrada del pulso
pinMode(13,OUTPUT);//salida del pulso
Wire.begin();
oled.begin(SSD1306_SWITCHCAPVCC,0x3C);
oled.clearDisplay();
oled.setTextColor(WHITE);
oled.setCursor(4,0);
oled.setTextSize(2);
oled.print("INDUCTANCE METER");
oled.display();
oled.setCursor(0,50);
oled.setTextSize(1);
oled.print("by Ing. Carlos Perez");
oled.display();
delay(5000);
digitalWrite(13, HIGH);
delay(100);
digitalWrite(13, LOW);
delayMicroseconds(100);
pulse= pulseIn(11,HIGH,5000);
if(pulse>0.1)
frequency=1.E6/(2pulse);
inductance=1./(capacitance
frequencyfrequency4.3.141593.14159);
inductance *=1E6;
//Serial.println(frequency);
oled.setCursor(0,30);
oled.setTextSize(5);
oled.print(pulse);
oled.display();
//delay(1000);
the original prog calculates this
inductance *=1E6;
inductance_mH = inductance *1000;
then they print the two at the same time
oled.print(inductance);
oled.print(inductance_mH);
What can I improve here??
It is no good reading it if you don't follow the advice it gives
If you have read it now did you decide to ignore the advice given ?
I'm a bit confused, but could you tell me what's the mistake, I explained the purpose of the project, and the code, and I describe what I EXPECT to happen, I do not have much experience in Forums but I would like to fit in
pcarlos683:
inductance *=1E6;
you sure that is how its calculated?
if
'inductance *=1E6;' give you the value in uH then surely to get the value in mH you would then do 'inductance/1000' NOT 'inductance *1000'.
anyway, to answer your question:
pcarlos683:
a simple if statement should do the trick to allow autoranging. somthing like this in your code maybe (below btw is the format the forum expects codes to be posted! :wink: ):
inductance *=1E6; //convert inductance to uH
if(inductance >=1000) inductance /=1000 ; //convert inductance to mH
hope that helps...
What was the advice given about how to post code ?
yep, it'll do the trick...sorry about the code, its a mess around here, I have like 3 pages open at the same time, I think once in an IF condition but wasn't sure that works, Im an Electric Engineer but my capabilities in C+ are limited to Matlab, this whole thing with Arduino makes my mind blow with old projects...
THANK YOU VERY MUCH
