Auto format not formatting correctly
This is really low priority, but it's not 'nice':
If you declare an array like this:
static boolean States[][4] = {{1,0,1,0},{0,0,1,0},{0,1,1,0},{0,1,0,0},{0,1,0,1},{0,0,0,1},{1,0,0,1},{1,0,0,0}};
And then run auto format you'll get this:
    1,0,1,0  }
    0,0,1,0  }
    0,1,1,0  }
    0,1,0,0  }
    0,1,0,1  }
    0,0,0,1  }
    1,0,0,1  }
    1,0,0,0  }
Which is pretty good, although not what I would expect.
Problem is that if you run auto format repeatedly to keep your code formatted right (like I do) you'll eventually end up with something like this:
    1,0,1,0                                              }
    0,0,1,0                                              }
    0,1,1,0                                              }
    0,1,0,0                                              }
    0,1,0,1                                              }
    0,0,0,1                                              }
    1,0,0,1                                              }
    1,0,0,0                                              }
After a few programming sessions the closing } will disappear from your window.
John
Yes, I had noticed that, however I do not autoformat very often at all...
I presume you were expecting what should happen which is:
    1,0,1,0
    0,0,1,0
    0,1,1,0
    0,1,0,0
    0,1,0,1
    0,0,0,1
    1,0,0,1
    1,0,0,0
or something similar
Mowcius
If I could choose I would like something like this:
    {1, 0, 1, 0},
    {0, 0, 1, 0},
    {0, 1, 1, 0},
    {0, 1, 0, 0},
    {0, 1, 0, 1},
    {0, 0, 0, 1},
    {1, 0, 0, 1},
    {1, 0, 0, 0}
But whatever formatting the Auto Format chooses, it should not change when repeatedly called.
John
Yes that is probably better...
Definitely a bug to be sorted...
Mowcius
