hello friend
how can I use this function so that it recevies Auto handshake without certificate???
exp : when using class esp8266secure can get data handshake & its dosent need cert.h class or function & gets the certificate automaticaly the same as chrome browser when searching the web site
what library do you use for ssl and ethernet (Auto Handshake) ?
thx..
what library do you use for secure connection over Ethernet? and what board do you use?
My board : esp8266-12F
Ethernet Controller : ENC28j60
Lib : UIPEthernet for ethernet but i can change it if it helps ....
now
EthernetClient sslClient;
BearSSLClient client(sslClient);
client.connect(Link , 443);
but this code can not handshake certificate ssl & need hard code certificate statics
use the new lwIP_enc28j60 bundled with esp8266 arduino. it adds a new network interface and you work with it over the WiFi library same way as with the STA interface and SoftAP interface
do you have an example for this library ?
in ESP8266WiFi library examples section in Arduino IDE
I have checked all the libraries none of them handshakes the certificate
if you use the lwIP_enc28j60 then you can use the same code as you used for WiFi
#include <WiFiClientSecure.h>
#include <ArduinoJson.h>
#include <FS.h>
#include "ESP8266httpUpdate.h"
//#include <SSLClient.h>
#include <EthernetENC.h>
//#include <BearSSLClient.h>
//#include <ArduinoBearSSL.h>
//WiFiClientSecure client;
Ethernet.init(15);
// Ethernet sslClient;
// sslClient.setInsecure();
// BearSSLClient sslClient(client);
// sslClient.available();
// sslClient.setClient(client1);
// BearSSLClient sslClient (client, TAs, (size_t)TAs_NUM);
// EthernetSSLClient sslClient(client, TAs, (size_t)TAs_NUM);
// SSLClient.setInsecure();
//EthernetSSLClient sslClient(client);
// SSLClient sslClient(client, TAs, (size_t)TAs_NUM,1);
sslClient.setTimeout(10000);
// client.setInsecure();
Serial.println("-->connecting to " + String("assess.mmaviot.com") + ":" + String("443"));
const char* Server_hub = "assess.mmaviot.com";
if (sslClient.connect(Server_hub, 443)) {
sslClient.print( String("GET ") + "/gadget/skeleton?serial=swr012108031138&uid=95f916e0-56d6-487f-82dd-da75b14081cb" + " HTTP/1.1\r\n" + "Host: " + Server_hub + "\r\n" + "Connection: close" + "\r\n\r\n");
Serial.println("request sent");
Serial.flush();
char status[20] = {0};
sslClient.readBytesUntil('\r', status, sizeof(status));
Serial.println("Command :");
// Serial.println(command_get);
Serial.println("Status :");
Serial.println(status);
Serial.println("Status Size:");
Serial.println(String(sizeof(status)));
if (strcmp(status + 9, "200 OK") == 0)
Serial.println("Connection Success");
// TLS = true;
while (sslClient.connected()) {
char endOfHeaders[] = "\r\n\r\n";
if (sslClient.find(endOfHeaders)) {
String Data_Server = sslClient.readString();
// AnsTLS = Data_Server;
Serial.println(Data_Server);
else {
Serial.println("** Connection Failed **");
sslClient.stop();
sslClient.flush();
// TLS = false;
Serial.println("");
Serial.println(" Connection Failed ");
Serial.println("");
And i got an error
ets Jan 8 2013,rst cause:2, boot mode:(3,2)
load 0x4010f000, len 3460, room 16
tail 4
chksum 0xcc
load 0x3fff20b8, len 40, room 4
tail 4
chksum 0xc9
csum 0xc9
v00045c40
~ld
why do you use EthermetENC + SSLClient and not the lwIP_enc28j60 library?
do you have a code which works over ESP8266WiFi library?
i haven't used these libraries (sslclient ) & comment this line
i want used lwIP_enc28j60 & ethernetclient
yes my code for ESP8266WiFi :
WiFiClientSecure espClient;
PubSubClient client(espClient);
espClient.setInsecure();
if (!client.connected()) {
Serial.print("Attempting MQTT connection...");
// Attempt to connect
if (client.connect("", Orphic.Server_User, Orphic.Server_Pass))
{ //serial //user //pass
i have used these codes for connection with wifi
and it works with out any problems
but i have problems with getting certificate ssl (Handshake) with ethernet (enc28j60)
isnt "lwIP_enc28j60 " library the EthernetENC ?? or are they different ?
the examples for "lwIP_enc28j60 " library are mostly from "EthernetENC" ![]()
totally and completely different libraries.
lwIP_enc28j60 is part of the esp8266 core.
combine following sketch with yours
This sketch establishes a TCP connection to a "quote of the day" service.
It sends a "hello" message, and then prints received data.
#include <SPI.h>
#include <ENC28J60lwIP.h>
#include <ESP8266WiFi.h>
const char* host = "djxmmx.net";
const uint16_t port = 17;
#define CSPIN D1
ENC28J60lwIP eth(CSPIN);
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress server(23, 28, 179, 206);
WiFi.mode(WIFI_OFF);
SPI.begin();
// if (!eth.config(ip, gw, nm, gw, IPADDR_NONE)) {
// Serial.println("wrong config");
eth.setDefault(); // use ethernet for default route
if (!eth.begin(mac)) {
Serial.println("ethernet hardware not found ... sleeping");
while (1) {
Serial.print("connecting ethernet");
while (!eth.connected()) {
Serial.print(".");
Serial.print("ethernet IP address: ");
Serial.println(eth.localIP());
Serial.println(eth.gatewayIP());
Serial.println(eth.subnetMask());
Serial.println(WiFi.dnsIP());
static bool wait = true;
Serial.print("connecting to ");
Serial.print(host);
Serial.print(':');
Serial.println(port);
WiFiClient client;
if (!client.connect(host, port)) {
Serial.println("connection failed");
delay(5000);
return;
// This will send a string to the server
Serial.println("sending data to server");
if (client.connected()) {
client.println("hello from ESP8266");
// wait for data to be available
unsigned long timeout = millis();
while (client.available() == 0) {
if (millis() - timeout > 5000) {
Serial.println(">>> Client Timeout !");
client.stop();
delay(60000);
return;
// Read all the lines of the reply from server and print them to Serial
Serial.println("receiving from remote server");
// not testing 'client.connected()' since we do not need to send data here
while (client.available()) {
char ch = static_cast<char>(client.read());
Serial.print(ch);
// Close the connection
Serial.println("closing connection");
client.stop();
if (wait) {
delay(300000); // execute once every 5 minutes, don't flood remote service
wait = true;
Thank you for your immediate response
connecting ethernet...
ethernet IP address: 192.168.1.105
192.168.1.1
255.255.255.0
192.168.1.1
connecting to djxmmx.net:17
connection failed
connection failed
connection failed
connection failed
connection failed
connection failed
"Oh the nerves, the nerves; the mysteries of this machine called man!
Oh the little that unhinges it, poor creatures that we are!"
Charles Dickens (1812-70)
i cant connect my server ![]()
connecting to assess.mmaviot.com:443
request sent
Command :
Status :
HTTP/1.1 400 Bad Req
Status Size:
20
Print Data Available
uest
Server: nginx/1.14.2
Date: Fri, 20 Aug 2021 16:49:55 GMT
Content-Type: text/html
Content-Length: 271
Connection: close
400 Bad Request
The plain HTTP request was sent to HTTPS portnginx/1.14.2
closing connection
Code :
#include <SPI.h>
const char* host = "assess.mmaviot.com";
const uint16_t port = 443;
#define CSPIN 15
IPAddress server(103, 130, 144, 73);
SPI.begin();
while (1) {
Serial.print(".");
Serial.print(host);
Serial.print(':');
WiFiClient client;
delay(5000);
return;
String command_get = "/gadget/skeleton?serial=swr012108031138&uid=95f916e0-56d6-487f-82dd-da75b14081cb";
delay(20);
client.println( String("GET ") + command_get + " HTTP/1.1\r\n" + "Host: " + "assess.mmaviot.com" + "\r\n" + "Connection: close" + "\r\n\r\n");
Serial.flush();
client.readBytesUntil('\r', status, sizeof(status));
// TLS = true;
while (client.connected()) {
if (client.find(endOfHeaders)) {
String Data_Server = client.readString();
else {
// client.println("hello from ESP8266");
client.stop();
delay(60000);
return;
Serial.println("Print Data Available");
Serial.print(ch);
client.stop();
if (wait) {
wait = true;
you can connect. 400 Bad request is a response from the server telling you that the request doesn't match the HTTP protocol
try to remove all that " + "
yes , i connect to server
but i can't get data from server
i edited my code as you said
GET /gadget/skeleton?serial=swr012108031138&uid=95f916e0-56d6-487f-82dd-da75b14081cb HTTP/1.1 HTTP/1.1\r\nHost: assess.mmaviot.com\r\nConnection: close\r\n\r\n
but this code worked with wifi mode before.
i dont know where the problem is , only the request class has changed & the request method is the one that worked before ...
connected to server but no encryption data !! and i get this error ...
400 The plain HTTP request was sent to HTTPS portHTTP/1.1 400 Bad Request
Date: Sun, 22 Aug 2021 15:08:46 GMT
Content-Length: 271
Connection: close
<html>
<head><title>400 The plain HTTP request was sent to HTTPS port</title></head>
<body bgcolor="white">
<center><h1>400 Bad Request</h1></center>
<center>The plain HTTP request was sent to HTTPS port</center>
<hr><center>nginx/1.14.2</center>
</body>
</html>
this library sends data in plain text mode & doesnt encrypt data
thats why nginx gives error 400 bad request
do you use your MQTT code with WiFiClientSecure?
