Auto Power off after certain time not working in micro
i tried to create the circuit from this 2 tutorila that ower on the ardinuo with pushbutton and shuts off after 5 second with Ardinuo micro and mega.
it works fine in mega.
but in pro it works first time when in push the button and ardinuo shuts off after 5 sec but second time i push the button it lights all the light in the board but does not hold the power for 5 sec. it works when in push the reset pin after ardinuo gets power.
any idea?
http://www.zolalab.com.br/eletronica_projetos/auto_shutdown_enus.php
// Pin definitions
#define OLED_RESET 4
const int MOSFETPIN = A1;
void setup(void)
pinMode(MOSFETPIN, OUTPUT);
digitalWrite(MOSFETPIN, HIGH);
delay(5000);
digitalWrite(MOSFETPIN, LOW);
If the Micro uses 3.3V logic, the Mosfet might be totally turned on or off due to the gate not being driven completely open or closed at 3.3VDC.
it works after 5 sec holding the push button. i think the boot loader is doing something.
also find out that after ardinuo shuts off all the pins are getting high.
Leroy2007:
it’s running on 5v.
// Pin definitions
void setup(void)
  pinMode(7, OUTPUT);
 digitalWrite(7, HIGH);
  delay(10000);
this one turned the ardinuo off after 10 sec but led was not turned off.
is there a circuit that works and different from this 2 i have?
here it says i can't power the ardinuo with one mosfet.
https://circuitjournal.com/arduino-auto-power-off
