auto projector screen control
im thinking of using my projector (canon sx-80) to automatically control my motorized projector screen but i dont have a 12v trigger output from my projector. i do have an RS45 output that might be useful? I've been researching all over the internet for a project similar to this but no luck so far. I have an arduino uno R3 board and 5v 2 channel relay connected but i dont know how to write the script to program it. I'd surely appreciate some assistance. Thanks.
you will likely need to get your hands on the data sheets for both the projector and screen motor. what output methods does the projector use (serial data, voltage, etc) and then what kind of input does the motor have on the same front. from there, you can plan your integration into Arudino. my spidey since tells me though - if you knew that information - you could just wire up the matching inputs/outputs without a Arduino controller. If there is mismatch (volts out, digital in) then you can bridge that with arduino.
poor mans version - have an arduino control a servo to push the screen's motor button :slight_smile: could then hook up an IR to the arduino. would not need to know any pin outs on either screen or projector.
