Auto range voltmeter FYI
Here is what I did recently in a small project.
A method to have an auto range voltmeter.
     //   M O D E  # 4   V O L T M E T E R
  case 4:
            int temp = 0;
            byte scaleFactor = 3;
            digitalWrite(range,LOW);     //Turn OFF the auto range Opto FET  0-15 volts
            temp = analogRead(voltageIn);
            delay (100);
            //are we below the threshold (0-5 volts)?
            if (temp <= 350)
              //we are  in the range of 0-5 volts
              //turn ON the auto range Opto FET
              digitalWrite(range,HIGH);
              scaleFactor = 1;
      // subtract the last reading:
      total = total - readings[index];
      // read twice the voltage on Pin A0:
      delay(100);
      readings[index] = analogRead(voltageIn);
      // add the reading to the total:
      total = total + readings[index];
      // advance to the next position in the array:
      index = index + 1;
      // if we're at the end of the array...
      if (index >= numReadings)
        // ...wrap around to the beginning:
        index = 0;
      // calculate the average:
      average = total / numReadings;
      //use 5060 to compensate for the 1K resistor
       i = map(average, 0, 1023, 0,5060 );
       i = i * scaleFactor;
That's cool.
Can you do auto positive and negative voltages too ?
Neat trick - are there higher voltage opto-isolated FETs I wonder? That H11F2 is
rated +/-30V breakdown.
For bipolar use you'd reference to a 2.5V and add protection diodes to the ground rail too.
Adding a 10nF cap to the output would remove high frequency noise and give more
reliable analogRead() output.
See: Kelivin contact polarity diagram on the data sheet. Maybe one could modify it.
https://www.fairchildsemi.com/datasheets/H1/H11F3M.pdf
2.5/1.1 volt reference might be next.
Actually there is a capacitor off sheet.
30 volt break down is a problem, but all my applications are less that 24v 15v.
LarryD:
Thanks ! I have never seen something like that. The "kelvin contact polarity" is like a cross-over switch with 4 of those optocouplers.
You can use DPDT relays but then there is a click click click thing to deal with.
You don't need to polarity switch, just read a bipolar voltage by referencing to
mid-rail... Loses one bit though.
mid-rail...
Yes, that too.
