try to do what you told me
but now it doesn't work at all
all I get is the Green led (also i have added sireal.print to see where is the problem - and I get junk.....)
this is the code
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(10,0,0,155); // ip in lan
EthernetServer server(80); //server is using port 80
int PIRChannel=4;
int GreenLED=9;
int RedLED=7;
int d;
Ethernet.begin(mac, ip);
server.begin();
pinMode(GreenLED,OUTPUT);
pinMode(RedLED,OUTPUT);
pinMode(PIRChannel,INPUT);
pir_cheak();
while (d==1)
digitalWrite(GreenLED,LOW); // Movement - Red LED
digitalWrite(RedLED,HIGH);
Serial.println ("move!!!");
if (d==0)
digitalWrite(RedLED, LOW);
digitalWrite(GreenLED,HIGH);
Serial.println("No move");
// listen for incoming clients
if (client) {
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
// see if HTTP request has ended with blank line
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println();
//meta-refresh page every 1 seconds
client.println("<HTML>");
client.print("<HEAD>");
client.print("<meta http-equiv=\"refresh\" content=\"1\">");
client.print("<TITLE /> Test</title>");
client.print("</head>");
client.println("<BODY>");
client.print("autorefresh test ");
client.println("
// printing the message
if (d=0)
client.print("All Good - No Movement");
client.print("
client.print("Warning - Movement");
client.print("
if (c == '\n') {
// you're starting a new line
else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
int pir_cheak()
if (digitalRead(PIRChannel) ==HIGH) // no movement - Green LED
d=0;
// Serial.println(d);
d=1;
Inside the while loop, you never change d. If d ever were 1, you'd go into an infinite loop.
By now, you'd think that you would have figured out that the code is doing something. You want it to do something. Presumably, "it doesn't work" means that those two somethings are not the same thing. So, if you ever get around to telling us what those two somethings are, then we can get to the point where the two somethings ARE the same thing.
pir_cheak() is defined to return an int. So, where is the necessary return statement? Why don't you expect, and use, the returned value?
Do you even know if you are reading the PIR data correctly?
O.K
this is way I'm asking here , I'm new at this and if I do something wrong I need someone tell that - so I'll learn for the next time.
All I want to do is simple thing
when the sensor is "on" - he will print out a message --> MOVE!!!! , red led will go on and green off
when the sensor is off - he will print out --> ALL GOOD!!!!! , green led will go on and red off
if I do this only with serial.print - it's work fine.
the problem begin when I want to use the card as a server.and start to write HTML code.
I hope now you understand.
this is my last code :
#include <SPI.h>
int PIRChannel=4;
int GreenLED=7;
int RedLED=9
int d;
server.begin();
pir_cheak();
if (d==0)
digitalWrite(GreenLED,HIGH); // No Movement - green LED
digitalWrite(RedLED,LOW);
digitalWrite(RedLED, HIGH);
if (client) {
client.println();
client.println("
if (d=0)
client.print("
client.print("
if (c == '\n') {
delay(1);
client.stop();
int pir_cheak()
Serial.println ("no move!!!");
d=0;
Serial.println ("Move!!!");
d=1;
return d;
You have reinserted the previous error into your code.
// this is not correct
if (d=0)
client.print("
client.print("
you are right , I have noticed it just now and fix it.
now it is almost working like I want to.
2 more things I want to know how to do
I want the redLED will be on from 5 sec. where do I need to put the delay?
now the led is not stable when there is a movement.
I want that the error message will be written in the side - I need to get the RTC next week and I want to when ever there is a movement it will "save" me the time .
this is the code so far :
#include <SPI.h>
int PIRChannel=4;
int GreenLED=7;
int RedLED=9
int d;
server.begin();
pir_cheak();
if (d==0)
if (client) {
client.println();
client.println("
if
(d==0)
client.print("
client.print("
if (c == '\n') {
delay(1);
client.stop();
int pir_cheak()
d=0;
d=1;
return d;
The millis() function returns the number of milliseconds since the program started.
unsigned long updateTime;
// when there is motion and you turn on the LED, do this
updateTime = millis();
updateTime += 5000;
// Now call millis in the "turn off" section and compare the value returned to updateTime
if(updateTime < millis())
// it has been 5 seconds
// you can turn off the LED
edit: I prefer using the web response to reset the flag for that.
int motionDetect = 0;
// then when you turn on the LED
motionDetect = 1;
// after you read the webpage
// like after client.stop(), then do this
motionDetect = 0;
That way it will store that value in case you don't communicate with the Arduino for a while for some reason or another.
if I'm using the web response option - where do I put the int?
at the pir_cheak function?
and another thing - I'm trying to keep the message at screen as long as the red LED is on.
and it's doesn't doing it - it only write the message once , and then return to "all-good"( this is not good)
I need the message will stay as long as the led is on.
I have change a few thing but still no good
#include <SPI.h>
int PIRChannel=4;
int GreenLED=7;
int RedLED=9;
int d;
server.begin();
pir_cheak();
if (client) {
client.println();
client.println("
if
(d==0)
client.print("
client.print("
client.print (millis()/1000);
client.print("
if (c == '\n') {
delay(1);
client.stop();
int pir_cheak()
if (updateTime < millis())
Serial.println(millis()/1000);
d=0;
d=1;
updateTime +=5000;
return d;
[code]
If you are using the variable 'd' for the message send, then don't clear 'd' until the time is up. Move it inside the time compare decision.
// do not use three of these. That can cause problems
// Serial.println ("no move!!!");
Serial.println ("no move!");
// this is cleared only when the time is up
d=0;
SurferTim - Thank you - now it's just like I want it
PaulS - I didn't know there is an option like this (it's wonderful ,and I'm using this option now - so thank you to!).
the lest thing that I want to do is - how to save the massage in another table ? , I have search the web but didn't find in the HTML basic how to do this.
I want whenever I get a move message - it will also save me the time on the side (meanwhile it will show me the sec using the millis() ).
