Auto reset circuit
Hi all,
I'm having trouble getting a definitive circuit for the auto reset, for example looking at the schematics for several boards...
Mega - Uses DTR through a cap but has a solder bridge that appears to do nothing, also uses RTS through a resistor to RST. Why both and what's with the bridge in parallel with a bare wire?
Duemilanove - same as mega.
Sanguino - Uses RTS through a cap and jumper. This makes sense but is way different to the official circuits.
Rob
I believe that the Arduino IDE software activates both the RTS and DTR signals when it wants to reset the board prior to an upload, so you can use either one. I believe the board schematic drawing will have an indication that the RTS resistor is not mounted. The 'solder bridge' is just a place where you can cut and break the auto-reset signal path, thus disabling the auto-reset feature.
Same answer
Again same answer, either RTS or DTR signals can be used, no need to use both.
Lefty
Thanks Lefty.
Looking at the schematics again I see that the resister is a "100_NM", I didn't pick that to mean "Not mounted".
