Auto run sketch
Now my servo motor runs whenever I press a button. How can I make it run once also when I plug in Arduino to the power supply?
Thank you!
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
#define servoPin 3 //~
#define pushButtonPin 2
int angle =45;    // initial angle  for servo (beteen 1 and 179)
int angleStep =10;
const int minAngle = 45;
const int maxAngle = 50;
const int type =2;//watch video for details. Link is at the top of this code (robojax)
int buttonPushed =0;
  // Servo button demo by Robojax.com
  Serial.begin(9600);          //  setup serial
  myservo.attach(servoPin);  // attaches the servo on pin 3 to the servo object
  pinMode(pushButtonPin,INPUT_PULLUP);
   Serial.println("Robojax Servo Button ");
   myservo.write(angle);//initial position
  if(digitalRead(pushButtonPin) == LOW){
    buttonPushed = 1;
   if( buttonPushed ){
  // change the angle for next time through the loop:
  angle = angle + angleStep;
    // reverse the direction of the moving at the ends of the angle:
    if (angle >= maxAngle) {
      angleStep = -angleStep;
        if(type ==1)
            buttonPushed =0;
    if (angle <= minAngle) {
       if(type ==2)
            buttonPushed =0;
    myservo.write(angle); // move the servo to desired angle
      Serial.print("Moved to: ");
      Serial.print(angle);   // print the angle
      Serial.println(" degree");
  delay(200); // waits for the servo to get there
3 posts were merged into an existing topic: May Arduino execute sketch on power supply?
