Auto sleep Arduino uno and auto turn on when the sensor is triggered
Here's the problem with the project, I tried to open the arduino for 24hrs (without the solar panel) using solar charge controller and 12V7.2a lead acid battery to see how long does the battery will last.
But after 10-12 hours the battery drained. So to save the life of the battery, I want the arduino to auto sleep or turn off if the sensor is not using for 10minutes or more, and auto turn on when the sensor is triggered.
How can i do that in the code? Using below code
#include <Wire.h>
#include <TimeLib.h>
#include <DS1307RTC.h>
int X;
int Y;
int t = 0;
int i = 0;
int check = 1;
int chk = 0;
int P = A3;
int N = A2;
int tim = 0;
float Time = 0;
float frequency = 0;
float waterFlow = 0;
float total = 0;
float LS = 0;
float average = 0;
const int input = A0;
const int test = 9;
pinMode(input, INPUT);
pinMode(P, OUTPUT);
pinMode(N, OUTPUT);
digitalWrite(P, HIGH);
digitalWrite(N, LOW);
for (i = 0; i < sec; i++)
Serial.println("AT+CNMI=2,2,0,0,0");
Serial.println("AT+CMGF=1");
Serial.println("AT+CMGS=\"+91xxxxxxxxxx\"\r"); // Replace x with mobile number
Serial.println("Your water supply notification system is ready.");// The SMS text you want to send
delay(100);
Serial.println((char)26); // ASCII code of CTRL+Z
tmElements_t tm;
if (RTC.read(tm))
if (tm.Hour > 12) //24Hrs to 12 Hrs conversion//
if (tm.Hour == 13) tim = 1;
if (tm.Hour == 14) tim = 2;
if (tm.Hour == 15) tim = 3;
if (tm.Hour == 16) tim = 4;
if (tm.Hour == 17) tim = 5;
if (tm.Hour == 18) tim = 6;
if (tm.Hour == 19) tim = 7;
if (tm.Hour == 20) tim = 8;
if (tm.Hour == 21) tim = 9;
if (tm.Hour == 22) tim = 10;
if (tm.Hour == 23) tim = 11;
tim = tm.Hour;
X = pulseIn(input, HIGH);
Y = pulseIn(input, LOW);
Time = X + Y;
frequency = 1000000 / Time;
waterFlow = frequency / 7.5;
LS = waterFlow / 60;
if (frequency >= 0)
if (isinf(frequency))
if (chk == 1)
Serial.print("Time: ");
delay(10);
Serial.print(tim);
delay(10);
Serial.print(":");
delay(10);
Serial.print(tm.Minute);
delay(10);
if (tm.Hour >= 12)
Serial.println(" PM");
if (tm.Hour < 12)
Serial.println(" AM");
delay(10);
Serial.println("Water Supply is Ended.");// The SMS text you want to send
delay(100);
Serial.print("Average Water Flow (Litre/Min): ");
delay(100);
Serial.println(average);
delay(100);
Serial.print("Total Water Delivered: ");
delay(100);
Serial.print(total);
delay(100);
Serial.println(" Litre");
delay(100);
delay(5000);
t = 0;
total = 0;
average = 0;
chk = 0;
check = 1;
if (check == 1)
delay(10);
Serial.print(tim);
delay(10);
Serial.print(":");
delay(10);
delay(10);
if (tm.Hour >= 12)
if (tm.Hour < 12)
delay(10);
Serial.println("The water is being supplied now.");// The SMS text you want to send
delay(100);
check = 0;
chk = 1;
t = t + 1;
total = total + LS;
average = total / t;
average = average * 60;
Do you know the amount of power being used by the sensor? Seems like the GSM board would use a lot more power.
6v, or i need higher amphere for battery for longer lifespan?
Finding such numbers is critical for any project design.
Something else is not right.
An Uno can in theory run about 250 hours off a 7Ah lead/acid battery.
Leo..
what do u think is the problem in the circuit?
That's for you to find out. Start measuring currents.
I have learned not to trust Fritzing pictures,
as they almost never represent the real situation.
I would run the 'Blink' sketch on the Uno, with nothing else connected to it.
See how long the battery then lasts.
Leo..
