Hey all,
Thank you everyone for your time so far. Thanks to @alto777 i have managed to install the shifter into the car. I have also modified the original code and changed the neo pixels to a 7 segment display. I have managed to get this sorted.
However I am hoping I can get some help with the gear up and gear down buttons. I am wanting the button to only change the state when pressed once. Currently if i hold the button it will automatically go through all 4 states. But for a fail safe i want it to be pressed once change the state then register that the button has been released before being able to change to the next gear. I have posted the current code but would someone please point me in the right direction of how to code the switch?
type or paste code here// Pin Definitions
const int SS1R = 2;
const int SS2R = 3;
const int FCSR = 4;
const int LUSR = 5;
const int GUS = 7;
const int GDS = 8;
const int ICRS = 13;
const int COIL1_4 = 9;
const int COIL2_3 = 10;
const int S7A = A4;
const int S7B = A5;
const int S7C = A1;
const int S7D = A0;
const int S7E = 12;
const int S7F = A3;
const int S7G = A2;
// Initialize pins
pinMode(SS1R, OUTPUT);
pinMode(SS2R, OUTPUT);
pinMode(FCSR, OUTPUT);
pinMode(LUSR, OUTPUT);
pinMode(GUS, INPUT_PULLUP);
pinMode(GDS, INPUT_PULLUP);
pinMode(ICRS, INPUT_PULLUP);
pinMode(COIL1_4, OUTPUT);
pinMode(COIL2_3, OUTPUT);
pinMode(S7A, OUTPUT);
pinMode(S7B, OUTPUT);
pinMode(S7C, OUTPUT);
pinMode(S7D, OUTPUT);
pinMode(S7E,OUTPUT);
pinMode(S7F,OUTPUT);
pinMode(S7G, OUTPUT);
// Start at G1
transitionToG1();
int theGear = 1; // what gear are we in global
static int currentState = 1;
if (digitalRead(GUS) == LOW) {
theGear++; if (theGear >= 4) theGear = 4;
if (digitalRead(GDS) == LOW) {
theGear--; if (theGear <= 0) theGear = 1;
static int currentGear = -1; // no, it does not!
// new gear?
if (theGear != currentGear) {
currentGear = theGear;
switch (theGear) {
case 1 :
transitionToG1();
case 2 :
transitionToG2();
case 3 :
transitionToG3();
case 4 :
transitionToG4();
default :
Serial.println("logic error");
for (; ; );
if (digitalRead(ICRS) == LOW) {
digitalWrite(COIL1_4, LOW);
digitalWrite(COIL2_3, LOW);
while (digitalRead(ICRS) == LOW); // Wait until ICRS goes HIGH
digitalWrite(COIL1_4, HIGH);
digitalWrite(COIL2_3, HIGH);
void transitionToG1() {
digitalWrite(SS1R, HIGH);
digitalWrite(SS2R, HIGH);
digitalWrite(FCSR, HIGH);
digitalWrite(LUSR, LOW);
digitalWrite(S7A, LOW);
digitalWrite(S7B, HIGH);
digitalWrite(S7C, HIGH);
digitalWrite(S7D, LOW);
digitalWrite(S7E, LOW);
digitalWrite(S7F, LOW);
digitalWrite(S7G, LOW);
triggerCoils();
void transitionToG2() {
digitalWrite(SS2R, LOW);
digitalWrite(S7A, HIGH);
digitalWrite(S7C, LOW);
digitalWrite(S7D, HIGH);
digitalWrite(S7E, HIGH);
digitalWrite(S7G, HIGH);
triggerCoils();
void transitionToG3() {
digitalWrite(SS1R, LOW);
digitalWrite(LUSR, HIGH);
digitalWrite(S7E, LOW) ;
triggerCoils();
void transitionToG4() {
digitalWrite(FCSR, LOW);
digitalWrite(S7F, HIGH);
triggerCoils();
void triggerCoils() {
delay(125);
Here is the Wokwi layout as well
