Auto watering code with milli()
Hi guys,
I am trying to make auto watering sytem with a soil moisture and i wanted to replace the delay() by milli()
the original code is this one wich is working:
 int moistureSensor = 2;
int relay = 3;
pinMode(relay, OUTPUT);
Serial.begin(9600); }
int sensorValue = digitalRead(moistureSensor);
// print out the value you read:
Serial.println(sensorValue);
digitalWrite(relay, HIGH);
if (sensorValue == 1) {
digitalWrite(relay, LOW);
Serial.println("Watering");
delay(10000);
// run pump for 10 seconds
Serial.println("Finished watering"); }
// delay 1 second between reads
And the problem with is i don’t get the serial println like : Serial.println(“Finished watering”)
unsigned long previousMillis = 0;
long Onpump = 1800000;;
long Offpump= 72000000;
int relay = 3;
if((sensorValue == 1) && (currentMillis - previousMillis >= Onpump))
else if ((sensorValue == LOW) && (currentMillis - previousMillis >= Offpump))
It will display 1 or 0 but that’s it; need some help to see what’s wrong.
You need to represent your state somehow - first identify the states and then the transitions between them and what causes each transition..
Hello,
Do you know about those wonderful things called Tropf Blumat ?
I think you need to disconnect the "needs water/does not need water" states from the timing actions.
You need to start watering, if not watering and if water is needed. That has NOTHING to do with time.
You need to stop watering, if watering and the plant is soaking wet. That has NOTHING to do with time.
If you are watering, and have been for a long time, stop. That has NOTHING to do with how wet/dry the soil is.
So should code be like this? Sorry I am bit confuse between the milli() and the moist sensor....
int relay = 3;
Wouldn't
  int moisturePinValue = digitalRead(moistureSensorPin);
make more sense?
bool needsWater = moisturePinValue == HIGH;
Compare the value read from the moisture sensor to HIGH. Assign the result to needsWater.
Now, you can do:
  if(needsWater)
     if(!watering)
       startWatering();
     // Soggy as all get out
     if(watering)
        stopWatering();
startWatering() would, obviously, set watering to true AND record when that happened. After that code, you would have:
   if(watering)
      if(millis() - startedWatering > timeToWater)
         stopWatering();
By using names that make sense, and putting code in appropriately named functions, the code almost writes itself.
Surely, you can figure out the types for watering (boolean), startedWatering (unsigned long), timeToWater (unsigned long), and appropriate (initial) values.
Surely, you can figure out what startWatering() and stopWatering() should do.
I too had a hard time learning to use millis() timing.
Part of that I think is the terrible variable names they chose. And that they always show a continuously repeating timer so it is hard to see where the timing starts and stops.
Here is an example that I hope more clearly shows how the timing starts and finishes.
unsigned long startTime = 0;
const long interval = 1000;  // 1 second = 1000 millis
bool timeFlag = false;
  if (something you want to Time) // <<<<< Put the sensor == 1 here
    timeFlag = true;
    startTime = millis();     // Begin timing sequence
    // do stuff here when timing sequence starts <<<<< turn pump on here
  unsigned long currentTime = millis();
  if (timeFlag == true && currentTime - startTime >= interval) // End timing sequence
    timeFlag = false;
    // do stuff here when time is up    <<<<<<<< turn pump off here
Thanks the answers look easier i gonna try this !
So i follow your instruction Hutkikz the code should be that?
This code is really bothering me when i put digitalWrite(relay, LOW); that should stop watering not start? [My pump is connected to the relay]
int relay = 3;
  if (sensorValue == 1) // <<<<< Put the sensor == 1 here
    timeFlag = true;
    timeFlag = false;
And i tryed as well with your advice PaulS but not very confident of the result :s
 int moistureSensorPin = 2;
int relay = 3;
Serial.println(moistureSensorPin);
  if(needsWater)
     if(!watering)
       startWatering();
digitalWrite(relay, LOW); // do I need this?
if(watering)
         stopWatering();
My code is a shame lol do you think i can find a code wich fit better my expectations?
should NOT be a global variable. Put it AFTER reading the pin, like I had done.
The } ALWAYS goes on a new line. Use white space between functions. Use Tools + Auto Format. Your code is hard as hell to read.
  if(needsWater)
It is NOT necessary to store the value of millis() in a variable.
Yes. IN A FUNCTION!
Does HIGH turn the relay on? Or does HIGH turn it off?
Where are the startWatering() and stopWatering() functions?
Thanks for the answers;
From what i have tried with the previous code low turn the relay on and high turn it off but doesn't make much sense for me
And i have the relay functions it's plug on the pin 3
Sorry PaulS i don't get where to go with the code what am i suppose to do with startWatering() and stopwatering()?
Don't the names suggest anything?
Everything that has to do with starting watering goes in the startWatering() function - turning the pump on, recording the time, setting the watering flag, etc.
Everything that has to do with stopping watering goes in the stopWatering() function - turning the pump off, clearing the time, clearing the watering flag, etc.
