I am using Windows 10
The board is Arduino/Genuino Uno
Port is correct as it is already labeled.
Everything during the upload goes fine till it gets to the last part. I have read all of the information from a troubleshooting perspective for uploading and nothing has helped. I even took the entire car apart and put it back together again but I still cannot get it to move .
This is the entire message that I am getting:
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM10
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xf0
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xf0
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xf0
Sketch uses 2282 bytes (7%) of program storage space. Maximum is 32256 bytes.
Global variables use 212 bytes (10%) of dynamic memory, leaving 1836 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM10 -b115200 -D -Uflash:w:C:\Users\Student\AppData\Local\Temp\arduino_build_721010/AUTO_GO.ino.hex:i
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Using Port : COM10
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x25
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x25
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x25
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x25
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x25
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x25
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x25
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x25
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x25
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x25
If anybody can help I would greatly appreciate it
