I'm using AutoConnect, with the following sketch :
#include <ESP8266WiFi.h>
#include <ESP8266HTTPClient.h>
#define GET_CHIPID() (ESP.getChipId())
#include <FS.h>
#include <PubSubClient.h>
#include <AutoConnect.h>
#include "DHT.h"
#define DHTPIN D6 // D3 was 0, was D2 on WeMos
#define DHTTYPE DHT11 // DHT 11
DHT dht(DHTPIN, DHTTYPE);
String t, h;
#define PARAM_FILE "/param.json"
#define AUX_MQTTSETTING "/mqtt_setting"
#define AUX_MQTTSAVE "/mqtt_save"
#define AUX_MQTTCLEAR "/mqtt_clear"
typedef ESP8266WebServer WiFiWebServer;
AutoConnect portal;
AutoConnectConfig config;
WiFiClient wifiClient;
PubSubClient mqttClient(wifiClient);
String serverName;
String channelId;
String userKey;
String apiKey;
String apid;
String hostName;
unsigned int updateInterval = 0;
unsigned long lastPub = 0;
#define MQTT_USER_ID "anyone"
bool mqttConnect() {
static const char alphanum[] = "0123456789"
"ABCDEFGHIJKLMNOPQRSTUVWXYZ"
"abcdefghijklmnopqrstuvwxyz"; // For random generation of client ID.
char clientId[9];
uint8_t retry = 3;
while (!mqttClient.connected()) {
if (serverName.length() <= 0)
mqttClient.setServer(serverName.c_str(), 1883);
Serial.println(String("Attempting MQTT broker:") + serverName);
for (uint8_t i = 0; i < 8; i++) {
clientId[i] = alphanum[random(62)];
clientId[8] = '\0';
if (mqttClient.connect(clientId, MQTT_USER_ID, userKey.c_str())) {
Serial.println("Established:" + String(clientId));
return true;
Serial.println("Connection failed:" + String(mqttClient.state()));
if (!--retry)
delay(3000);
return false;
void mqttPublish(String msg) {
String path = String("channels/") + channelId + String("/publish/") + apiKey;
mqttClient.publish(path.c_str(), msg.c_str());
int getStrength(uint8_t points) {
uint8_t sc = points;
long rssi = 0;
while (sc--) {
rssi += WiFi.RSSI();
delay(20);
return points ? static_cast<int>(rssi / points) : 0;
String loadParams(AutoConnectAux& aux, PageArgument& args) {
(void)(args);
File param = SPIFFS.open(PARAM_FILE, "r");
if (param) {
aux.loadElement(param);
param.close();
Serial.println(PARAM_FILE " open failed");
return String("");
String saveParams(AutoConnectAux& aux, PageArgument& args) {
serverName = args.arg("mqttserver");
serverName.trim();
channelId = args.arg("channelid");
channelId.trim();
userKey = args.arg("userkey");
userKey.trim();
apiKey = args.arg("apikey");
apiKey.trim();
String upd = args.arg("period");
updateInterval = upd.substring(0, 2).toInt() * 1000;
String uniqueid = args.arg("uniqueid");
hostName = args.arg("hostname");
hostName.trim();
// The entered value is owned by AutoConnectAux of /mqtt_setting.
// To retrieve the elements of /mqtt_setting, it is necessary to get
// the AutoConnectAux object of /mqtt_setting.
File param = SPIFFS.open(PARAM_FILE, "w");
portal.aux("/mqtt_setting")->saveElement(param, { "mqttserver", "channelid", "userkey", "apikey", "period", "uniqueid", "hostname" });
param.close();
// Echo back saved parameters to AutoConnectAux page.
AutoConnectText& echo = aux["parameters"].as<AutoConnectText>();
echo.value = "Server: " + serverName + "
echo.value += "Channel ID: " + channelId + "
echo.value += "User Key: " + userKey + "
echo.value += "API Key: " + apiKey + "
echo.value += "Update period: " + String(updateInterval / 1000) + " sec.
echo.value += "Use APID unique: " + uniqueid + "
echo.value += "ESP host name: " + hostName + "
return String("");
void handleRoot() {
String content =
"<html>"
"<head>"
"<meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">"
"</head>"
"<body>"
"<iframe width=\"450\" height=\"260\" style=\"transform:scale(0.79);-o-transform:scale(0.79);-webkit-transform:scale(0.79);-moz-transform:scale(0.79);-ms-transform:scale(0.79);transform-origin:0 0;-o-transform-origin:0 0;-webkit-transform-origin:0 0;-moz-transform-origin:0 0;-ms-transform-origin:0 0;border: 1px solid #cccccc;\" src=\"https://thingspeak.com/channels/454951/charts/1?bgcolor=%23ffffff&color=%23d62020&dynamic=true&type=line\"></iframe>"
"<p style=\"padding-top:10px;text-align:center\">" AUTOCONNECT_LINK(COG_24) "</p>"
"</body>"
"</html>";
WiFiWebServer& webServer = portal.host();
webServer.send(200, "text/html", content);
// Clear channel using Thingspeak's API.
void handleClearChannel() {
HTTPClient httpClient;
WiFiClient client;
String endpoint = serverName;
endpoint.replace("mqtt", "api");
String delUrl = "http://" + endpoint + "/channels/" + channelId + "/feeds.json?api_key=" + userKey;
Serial.print("DELETE " + delUrl);
if (httpClient.begin(client, delUrl)) {
Serial.print(":");
int resCode = httpClient.sendRequest("DELETE");
String res = httpClient.getString();
httpClient.end();
Serial.println(String(resCode) + "," + res);
Serial.println(" failed");
// Returns the redirect response. The page is reloaded and its contents
// are updated to the state after deletion.
webServer.sendHeader("Location", String("http://") + webServer.client().localIP().toString() + String("/"));
webServer.send(302, "text/plain", "");
webServer.client().flush();
webServer.client().stop();
// Load AutoConnectAux JSON from SPIFFS.
bool loadAux(const String auxName) {
bool rc = false;
String fn = auxName + ".json";
File fs = SPIFFS.open(fn.c_str(), "r");
if (fs) {
rc = portal.load(fs);
fs.close();
Serial.println("SPIFFS open failed: " + fn);
return rc;
Serial.println("Started DHT");
dht.begin();
Serial.println("API Key: " + String(apiKey));
SPIFFS.begin();
loadAux(AUX_MQTTSETTING);
loadAux(AUX_MQTTSAVE);
AutoConnectAux* setting = portal.aux(AUX_MQTTSETTING);
if (setting) {
PageArgument args;
AutoConnectAux& mqtt_setting = *setting;
loadParams(mqtt_setting, args);
AutoConnectCheckbox& uniqueidElm = mqtt_setting["uniqueid"].as<AutoConnectCheckbox>();
AutoConnectInput& hostnameElm = mqtt_setting["hostname"].as<AutoConnectInput>();
if (uniqueidElm.checked) {
config.apid = String("ESP") + "-" + String(GET_CHIPID(), HEX);
Serial.println("apid set to " + config.apid);
if (hostnameElm.value.length()) {
config.hostName = hostnameElm.value;
Serial.println("hostname set to " + config.hostName);
config.homeUri = "/";
portal.config(config);
portal.on(AUX_MQTTSETTING, loadParams);
portal.on(AUX_MQTTSAVE, saveParams);
Serial.println("aux. load error");
Serial.print("WiFi ");
if (portal.begin()) {
config.bootUri = AC_ONBOOTURI_HOME;
Serial.println("connected:" + WiFi.SSID());
Serial.println("IP:" + WiFi.localIP().toString());
Serial.println("connection failed:" + String(WiFi.status()));
while (1) {
delay(100);
yield();
webServer.on("/", handleRoot);
webServer.on(AUX_MQTTCLEAR, handleClearChannel);
h = (String)dht.readHumidity();
t = (String)dht.readTemperature();
portal.handleClient();
if (updateInterval > 0) {
if (millis() - lastPub > updateInterval) {
if (!mqttClient.connected()) {
mqttConnect();
String item = String("field1=") + String(getStrength(7));
// String item1 = String("field2=") + String(t);
// String item2 = String("field3=") + String(h);
mqttPublish(item);
// mqttPublish(item1);
// mqttPublish(item2);
mqttClient.loop();
lastPub = millis();
Serial.println("Temperature: " + String(t));
Serial.println("Humidity: " + String(h));
delay(5000);
I want to publish temperature and humidity from the DHT sensor in addition to the WiFi strength, but I am unable to currently achieve this. With the current code, only one field is published.
Any ideas ?
