I’m having trouble writing the code to turn on my Christmas tree lights whenever a PIR sensor detects someone in the room. I want to have it so that if the lights are off and the sensor detects movement it turns on the lights for 20 minutes. I also want to make it so that if the sensor does not detect movement within those 20 minutes then the lights turn off after the 20 minutes; if the sensor does detect someone within the first 20 minutes then the lights stay on for an additional 20 minutes. So every time a person is detected the 20 minutes is renewed.
Right now the lights turn on when someone is detected and they stay on for 20 minutes, but turn off when that 20 minutes is over (no matter how many times the sensor detects someone in the first 20 minutes). Can you help me spot what’s going wrong here? Thanks!
int pCount = 0; // Counts number of times sensor is activated
int count = 0; // Counts 20 second time intervals
pinMode(3, INPUT); // Input to read if motion sensor is activated
pinMode(6, OUTPUT); // Output to trigger relay to turn on lights
if (digitalRead(3) == HIGH) // Increases sensor counter is sensor is active
pCount++;
count++; // Increases time count only if sensor has been activated
delay(20000); // 20 second delay to limit frequency program checks sensor status
if (pCount > 0) // Checks to see if sensor has been activated
digitalWrite(6, HIGH); // Turns on lights
if (count >= 60) // IF statement at 20 minutes
count = 0; // resets both counters after 20 minutes
if (pCount < 2)
digitalWrite(6,LOW);
pCount = 0;
pCount = 1;
