Automated Dust Collection
I am copying a project I saw on youtube for my dust collection system. I have all of the components wired up, but when I turn the tool on, it isnt sending a signal to the relay to turn the dust collector on.
This script was created by Bob Clagett for I Like To Make Stuff
For more projects, check out iliketomakestuff.com
Includes Modified version of “Measuring AC Current Using ACS712”
http://henrysbench.capnfatz.com/henrys-bench/arduino-current-measurements/acs712-arduino-ac-current-tutorial/
Parts of this sketch were taken from the keypad and servo sample sketches that comes with the keypad and servo libraries.
Uses GitHub - adafruit/Adafruit-PWM-Servo-Driver-Library: Adafruit PWM Servo Driver Library
#include <Wire.h>
#include <Adafruit_PWMServoDriver.h>
// called this way, it uses the default address 0x40
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
// you can also call it with a different address you want
//Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(0x41);
// Depending on your servo make, the pulse width min and max may vary, you
// want these to be as small/large as possible without hitting the hard stop
// for max range. You’ll have to tweak them as necessary to match the servos you
// have!
// our servo # counter
uint8_t servoCount = 6;
uint8_t servonum = 0;
const int OPEN_ALL = 100;
const int CLOSE_ALL = 99;
boolean buttonTriggered = 0;
boolean powerDetected = 0;
boolean collectorIsOn = 0;
int DC_spindown = 3000;
const int NUMBER_OF_TOOLS = 3;
const int NUMBER_OF_GATES = 6;
String tools[NUMBER_OF_TOOLS] = {“Miter Saw”,“Table Saw”,“Band Saw”}; //, “Floor Sweep”
int voltSensor[NUMBER_OF_TOOLS] = {A1,A2,A3};
long int voltBaseline[NUMBER_OF_TOOLS] = {0,0,0};
//DC right, Y, miter, bandsaw, saw Y, tablesaw, floor sweep
//Set the throw of each gate separately, if needed
int gateMinMax[NUMBER_OF_GATES][2] = {
/open, close/
{250,415},//DC right
{230,405},//Y
{230,405},//miter
{285,425},//bandsaw
{250,405},//saw y
{250,415},//floor sweep
//keep track of gates to be toggled ON/OFF for each tool
int gates[NUMBER_OF_TOOLS][NUMBER_OF_GATES] = {
{1,0,1,0,0,0},
{1,1,0,0,1,1},
{1,1,0,1,0,0},
const int dustCollectionRelayPin = 11;
const int manualSwitchPin = 12; //for button activated gate, currently NOT implemented
int mVperAmp = 185; // use 100 for 20A Module and 66 for 30A Module
double ampThreshold = .20;
double Voltage = 0;
double VRMS = 0;
double AmpsRMS = 0;
//button debouncing
int state = HIGH; // the current state of the output pin
int reading; // the current reading from the input pin
int previous = LOW; // the previous reading from the input pin
// the follow variables are long’s because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long time = 0; // the last time the output pin was toggled
long debounce = 200; // the debounce time, increase if the output flickers
void setup(){
pinMode(dustCollectionRelayPin,OUTPUT);
pwm.begin();
pwm.setPWMFreq(60); // Default is 1000mS
//record baseline sensor settings
//currently unused, but could be used for voltage comparison if need be.
for(int i=0;i<NUMBER_OF_TOOLS;i++){
pinMode(voltSensor*,INPUT);*
voltBaseline = analogRead(voltSensor*);*
void loop(){
* // use later for button debouncing*
* reading = digitalRead(manualSwitchPin);*
* if (reading == HIGH && previous == LOW && millis() - time > debounce) {*
* if (state == HIGH){*
* state = LOW;*
* buttonTriggered = false;*
* } else{*
* state = HIGH;*
* buttonTriggered = true;*
* time = millis(); *
* previous = reading;*
* Serial.println("----------");*
* //loop through tools and check*
* int activeTool = 50;// a number that will never happen*
* for(int i=0;i<NUMBER_OF_TOOLS;i++){
_ if( checkForAmperageChange(i)){
activeTool = i;
exit;
if( i!=0){
if(checkForAmperageChange(0)){
activeTool = 0;
exit;
if(activeTool != 50){
// use activeTool for gate processing*
* if(collectorIsOn == false){
//manage all gate positions*
* for(int s=0;s<NUMBER_OF_GATES;s++){*
* int pos = gates[activeTool];
~~ if(pos == 1){
openGate(s);
closeGate(s);
turnOnDustCollection();
} else{
if(collectorIsOn == true){_
delay(DC_spindown);
_
turnOffDustCollection();
boolean checkForAmperageChange(int which){
Voltage = getVPP(voltSensor[which]);*
VRMS = (Voltage/2.0) 0.707;
AmpsRMS = (VRMS * 1000)/mVperAmp;~~
~~ Serial.print(tools[which]+": “);
Serial.print(AmpsRMS);
Serial.println(” Amps RMS");
if(AmpsRMS>ampThreshold){
return true;
}else{
return false;
void turnOnDustCollection(){
Serial.println(“turnOnDustCollection”);
digitalWrite(dustCollectionRelayPin,1);
collectorIsOn = true;
void turnOffDustCollection(){
Serial.println(“turnOffDustCollection”);
digitalWrite(dustCollectionRelayPin,0);
collectorIsOn = false;
}~~*_
float getVPP(int sensor)
~~ float result;~~
~~ int readValue; //value read from the sensor~~
~~ int maxValue = 0; // store max value here~~
~~ int minValue = 1024; // store min value here~~
~~ uint32_t start_time = millis();~~
~~ while((millis()-start_time) < 500) //sample for 1 Sec~~
~~ readValue = analogRead(sensor);~~
~~ // see if you have a new maxValue~~
~~ if (readValue > maxValue)~~
~~ /record the maximum sensor value/~~
~~ maxValue = readValue;~~
~~ if (readValue < minValue)~~
~~ minValue = readValue;~~
~~ // Subtract min from max~~
~~ result = ((maxValue - minValue) * 5.0)/1024.0;~~
~~ return result;~~
void closeGate(uint8_t num){
~~ Serial.print("closeGate ");~~
~~ Serial.println(num);~~
~~ pwm.setPWM(num, 0, gateMinMax[num][1]);~~
void openGate(uint8_t num){
~~ Serial.print("openGate ");~~
~~ pwm.setPWM(num, 0, gateMinMax[num][0]);~~
~~ delay(100);~~
~~ pwm.setPWM(num, 0, gateMinMax[num][0]-5);~~
I hope you see a problem with your post (ie., hard to read). Please take a few minutes to read through How to use this forum, especially the part on posting your code and using code tags. The latter will clean up your post.
We don't have you hardware, so we are not going to be able to test. You will have to tell us what hardware you have, how you have it wired (post a schematic), and what you have tried and the results.
I am using a acs712 to detect when a tool is turned on. I am using A0 pin to detect the signal and have the dust collector relay connected to digital pin 11
iltms_automated_dust_collection-master.zip (3.16 KB)
How about fixing the OP so it can be read.
What signals are you getting from the ACS712? (I'm hoping you have a voltmeter)
The serial plotter is showing the voltage increases from 3.5 volts to 5 when the tool is turned on. I am using a heat gun to similate a tool being turned on.
gladewater2016: The serial plotter is showing the voltage increases from 3.5 volts to 5 when the tool is turned on. I am using a heat gun to similate a tool being turned on.
Looks threatening ... ;)
 * This code is for the project at
 * http://www.iliketomakestuff.com/how-to-automate-a-dust-collection-system-arduino
 * All of the components are list on the url above.
Includes Modified version of "Measuring AC Current Using ACS712"
Uses https://github.com/adafruit/Adafruit-PWM-Servo-Driver-Library
#include <Wire.h>
// for max range. You'll have to tweak them as necessary to match the servos you
// have!
String tools[NUMBER_OF_TOOLS] = {"Miter Saw","Table Saw","Band Saw"}; //, "Floor Sweep"
  /*open, close*/
  {230,405},//Y
  {230,405},//miter
  {285,425},//bandsaw
  {250,405},//saw y
  {1,0,1,0,0,0},
  {1,1,0,0,1,1},
  {1,1,0,1,0,0},
double Voltage = 0;
double VRMS = 0;
double AmpsRMS = 0;
//button debouncing
// the follow variables are long's because the time, measured in miliseconds,
void setup(){
  pwm.begin();
    pinMode(voltSensor[i],INPUT);
    voltBaseline[i] = analogRead(voltSensor[i]);
void loop(){
    if (state == HIGH){
      state = LOW;
    } else{
      state = HIGH;
    time = millis();
  previous = reading;
        activeTool = i;
        exit;
      if( i!=0){
          activeTool = 0;
          exit;
        int pos = gates[activeTool][s];
        if(pos == 1){
          openGate(s);
          closeGate(s);
  } else{
        delay(DC_spindown);
   VRMS = (Voltage/2.0) *0.707;
   Serial.print(tools[which]+": ");
   Serial.println(" Amps RMS");
    return true;
   }else{
    return false;
  Serial.println("turnOnDustCollection");
  Serial.println("turnOffDustCollection");
  float result;
           /*record the maximum sensor value*/
   return result;
    delay(100);
@gladewater2016, how much experience do you have with the Arduinos?
Which Arduino do you have?
How many ACS712 do you have?
As I read the code, you need at least 2 (actually will need 4).
I am using the arduino uno and a adafruit 16x12 bit servo shield. If and when I get the project finished, It will be udes on 6 different tools, so there will be 6, acs712,. My arduino knowledge is very limited
How many ACS712 do you have now?
These two lines
Show which sensor is assigned to each tool.
These lines:
activeTool = i;
exit;
if( i!=0)
activeTool = 0;
exit;
check for the tool to be turned on.
If the one ACS712 you have is wired to A0, it will not cause the DC to turn on. Try plugging it into A1.
The program also has lots of output to the serial monitor. Can you post some using code tags.
I plugged it into A1. The serial plotter is showing a voltage increase when I turn the heat gun on. I am using a heat gun to similate the tool being turned on. I am not getting a signal to turn the dust collector relay on
Does the serial monitor show the arduino is trying to turn on the DC?
When I turn the heat gun on, the amps change from 0.07 to 5.40. So I guess the answer is yes..?
   activeTool = i;
   exit;
 if( i!=0)
     activeTool = 0;
     exit;
What do you think that the exit statements do in this snippet?
There should not be a guess. The text listed in post #11 will be printed in the serial monitor. The serial monitor is in the same menu and right above the Serial Plotter.
The serial monitor is where I am seeing the amp increase when I turn the heat gun on. It is showing a amp increase on the miter saw from 0.07 to 5.40
You never see it print "turnOnDustCollection"?
no
groundFungus:
  activeTool = i;
  exit;
if( i!=0)
    activeTool = 0;
    exit;
Find tool and exit loop(). Cute function. I’m thinking this doesn’t work very well.
Luckily I can admit that I didn’t write it.
I guess the million dollar question is, how do I fix it so it will turn on the dust collector and open a servo for the blast gate for the miter saw?
