Automated Dust Collection
This script was created by Bob Clagett for I Like To Make Stuff
For more projects, check out iliketomakestuff.com
Includes Modified version of “Measuring AC Current Using ACS712”
http://henrysbench.capnfatz.com/henrys-bench/arduino-current-measurements/acs712-arduino-ac-current-tutorial/
Parts of this sketch were taken from the keypad and servo sample sketches that comes with the keypad and servo libraries.
Uses GitHub - adafruit/Adafruit-PWM-Servo-Driver-Library: Adafruit PWM Servo Driver Library
#include <Wire.h>
#include <Adafruit_PWMServoDriver.h>
// called this way, it uses the default address 0x40
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
// you can also call it with a different address you want
//Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(0x41);
// Depending on your servo make, the pulse width min and max may vary, you
// want these to be as small/large as possible without hitting the hard stop
// for max range. You’ll have to tweak them as necessary to match the servos you
// have!
// our servo # counter
uint8_t servoCount = 6;
uint8_t servonum = 0;
const int OPEN_ALL = 100;
const int CLOSE_ALL = 99;
boolean buttonTriggered = 0;
boolean powerDetected = 0;
boolean collectorIsOn = 0;
int DC_spindown = 3000;
const int NUMBER_OF_TOOLS = 3;
const int NUMBER_OF_GATES = 6;
String tools[NUMBER_OF_TOOLS] = {“Miter Saw”,“Table Saw”,“Band Saw”}; //, “Floor Sweep”
int voltSensor[NUMBER_OF_TOOLS] = {A1,A2,A3};
long int voltBaseline[NUMBER_OF_TOOLS] = {0,0,0};
//DC right, Y, miter, bandsaw, saw Y, tablesaw, floor sweep
//Set the throw of each gate separately, if needed
int gateMinMax[NUMBER_OF_GATES][2] = {
/open, close/
{250,415},//DC right
{230,405},//Y
{230,405},//miter
{285,425},//bandsaw
{250,405},//saw y
{250,415},//floor sweep
//keep track of gates to be toggled ON/OFF for each tool
int gates[NUMBER_OF_TOOLS][NUMBER_OF_GATES] = {
{1,0,1,0,0,0},
{1,1,0,0,1,1},
{1,1,0,1,0,0},
const int dustCollectionRelayPin = 11;
const int manualSwitchPin = 12; //for button activated gate, currently NOT implemented
int mVperAmp = 100; // use 100 for 20A Module and 66 for 30A Module
double ampThreshold = .20;
double Voltage = 0;
double VRMS = 0;
double AmpsRMS = 0;
//button debouncing
int state = HIGH; // the current state of the output pin
int reading; // the current reading from the input pin
int previous = LOW; // the previous reading from the input pin
// the follow variables are long’s because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long time = 0; // the last time the output pin was toggled
long debounce = 200; // the debounce time, increase if the output flickers
void setup(){
pinMode(dustCollectionRelayPin,OUTPUT);
pwm.begin();
pwm.setPWMFreq(60); // Default is 1000mS
//record baseline sensor settings
//currently unused, but could be used for voltage comparison if need be.
for(int i=0;i<NUMBER_OF_TOOLS;i++){
pinMode(voltSensor*,INPUT);*
voltBaseline = analogRead(voltSensor*);*
void loop(){
* // use later for button debouncing*
* reading = digitalRead(manualSwitchPin);*
* if (reading == HIGH && previous == LOW && millis() - time > debounce) {*
* if (state == HIGH){*
* state = LOW;*
* buttonTriggered = false;*
* } else{*
* state = HIGH;*
* buttonTriggered = true;*
* time = millis(); *
* previous = reading;*
* Serial.println("----------");*
* //loop through tools and check*
* int activeTool = 50;// a number that will never happen*
* for(int i=0;i<NUMBER_OF_TOOLS;i++){
_ if( checkForAmperageChange(i)){
activeTool = i;
exit;
if( i!=0){
if(checkForAmperageChange(0)){
activeTool = 0;
exit;
if(activeTool != 50){
// use activeTool for gate processing*
* if(collectorIsOn == false){
//manage all gate positions*
* for(int s=0;s<NUMBER_OF_GATES;s++){*
* int pos = gates[activeTool];
~~ if(pos == 1){
openGate(s);
closeGate(s);
turnOnDustCollection();
} else{
if(collectorIsOn == true){_
delay(DC_spindown);
_
turnOffDustCollection();
boolean checkForAmperageChange(int which){
Voltage = getVPP(voltSensor[which]);*
VRMS = (Voltage/2.0) 0.707;
AmpsRMS = (VRMS * 1000)/mVperAmp;~~
~~ Serial.print(tools[which]+": “);
Serial.print(AmpsRMS);
Serial.println(” Amps RMS");
if(AmpsRMS>ampThreshold){
return true;
}else{
return false;
void turnOnDustCollection(){
Serial.println(“turnOnDustCollection”);
digitalWrite(dustCollectionRelayPin,1);
collectorIsOn = true;
void turnOffDustCollection(){
Serial.println(“turnOffDustCollection”);
digitalWrite(dustCollectionRelayPin,0);
collectorIsOn = false;
}~~*_
float getVPP(int sensor)
~~ float result;~~
~~ int readValue; //value read from the sensor~~
~~ int maxValue = 0; // store max value here~~
~~ int minValue = 1024; // store min value here~~
~~ uint32_t start_time = millis();~~
~~ while((millis()-start_time) < 500) //sample for 1 Sec~~
~~ readValue = analogRead(sensor);~~
~~ // see if you have a new maxValue~~
~~ if (readValue > maxValue)~~
~~ /record the maximum sensor value/~~
~~ maxValue = readValue;~~
~~ if (readValue < minValue)~~
~~ minValue = readValue;~~
~~ // Subtract min from max~~
~~ result = ((maxValue - minValue) * 5.0)/1024.0;~~
~~ return result;~~
void closeGate(uint8_t num){
~~ Serial.print("closeGate ");~~
~~ Serial.println(num);~~
~~ pwm.setPWM(num, 0, gateMinMax[num][1]);~~
void openGate(uint8_t num){
~~ Serial.print("openGate ");~~
~~ pwm.setPWM(num, 0, gateMinMax[num][0]);~~
~~ delay(100);~~
~~ pwm.setPWM(num, 0, gateMinMax[num][0]-5);~~
The monitor is showing the dust collector coming on and going off but not the gates opening
Miter Saw: 9.60 Amps RMS Table Saw: 0.02 Amps RMS Miter Saw: 9.55 Amps RMS Band Saw: 0.02 Amps RMS Miter Saw: 9.51 Amps RMS openGate 0 closeGate 1 openGate 2 closeGate 3 closeGate 4 closeGate 5 turnOnDustCollection
It is showing it is opening the gate
//Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
The above was what I posted to change the I2C address.
Your code is not the same. You have used the default constructor which uses the default address, 0x40.
Please post code in code tags. Do you look at your posts after you send them?
Im missing something. I dont see the difference.
// called this way, it uses the default address 0x40 Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(); // you can also call it with a different address you want //Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(0x40);
I couldnt figure out what you are talking about so I unsoldered the jumper. Is this right?
To set the address to the default, yes. Did it work? Did you run the I2C scanner again to see if the address changed?
Yes. I ran the scanner again, but it still doesnt work
I2C scanner. Scanning ... Found address: 65 (0x41) Found address: 112 (0x70) Done. Found 2 device(s). This is what it shows now
I ran the adafruit servo test program and none of the servos are working
The address of the servo shield is still 0x41. It appears the the blob removal was not effective.
Until you get the address in the code to match the address of the shield it won't work.
I put the blob back on.Then I ran the scan again.This is what I got. I2C scanner. Scanning ... Found address: 65 (0x41) Found address: 112 (0x70) Done. Found 2 device(s). Why is it showing two different devices?
// called this way, it uses the default address 0x41 Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(); // you can also call it with a different address you want //Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(0x41);
Im sorry Im not understanding what I need to do. Is this how it is suopposed to be? I really do appreciate you help!!
The double slashes (//) in front of a line tells the compiler to ignore that line. The line is a comment and is said to be commented out. In your rcode all of the lines except
are commented out. The line that is not commented is the the default constructor and assigns the default address (0x40) because there is no parameter for Adafruit_PWMServoDriver().
This is the code that I posted
The first 3 lines are commentd out (ignored). The only line that is not commented out is the last line.
That constructor includes a parameter for Adafruit_PWMServoDriver(0x41) to set the address to 0x41.
Idon't know what the other device address is for. What else is connected to your project?
The only other thing connected is the acs712 and the relay
// called this way, it uses the default address 0x40 //Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(); // you can also call it with a different address you want Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(0x41);
Is this how it is supposed to be?
Now that I changed the code, only one device is showing. I2C scanner. Scanning ... Found address: 65 (0x41) Done. Found 1 device(s).
But it still isnt working
gladewater2016: I put the blob back on.Then I ran the scan again.This is what I got. I2C scanner. Scanning ... Found address: 65 (0x41) Found address: 112 (0x70) Done. Found 2 device(s).
Summary is that you have the Arduino, Servo driver, ACS712, and the relay board. Nothing else. Only one of those uses I2C and uses one address. Something doesn't make sense. Take off the servo driver we suspect is at 0x41 and report the results.
gladewater2016:
I2C scanner. Scanning …
Done.
Found 1 device(s).
Changed what code? Did you change something in the I2C Scanner code?
I got everything working now except for the timing of the servos. Thats another day after I do more research. I changed the address in the scanner and the second device went away
Should I start another post for help with the servos?
