Here is my grow light code that works very well. Perhaps it will give a few hints.
I use the internal Real Time Clock of the ESP32. I set the clock at boot and check the time once in a while to see if the grow light status needs to change.
#include <WiFi.h>
#include <PubSubClient.h>
#include "certs.h"
#include "sdkconfig.h"
#include "esp_system.h"
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "freertos/timers.h"
#include "freertos/event_groups.h"
#include "time.h"
hw_timer_t * timer = NULL;
EventGroupHandle_t eg;
#define evtDoDisplay ( 1 << 1 )
#define evtParseMQTT ( 1 << 5 )
#define evtDoTheSunLampThing ( 1 << 10 )
int SunLampManual = 0;
int SunLampAuto = 0;
WiFiClient wifiClient;
PubSubClient MQTTclient( mqtt_server, mqtt_port, wifiClient );
String str_eTopic;
char strPayload [300] = {'\0'};
byte mac[6];
SemaphoreHandle_t sema_MQTT_Parser;;
SemaphoreHandle_t sema_DoTheSunLampThing;
SemaphoreHandle_t sema_MQTT_KeepAlive;
volatile int iDoTheThing = 0;
void IRAM_ATTR onTimer()
BaseType_t xHigherPriorityTaskWoken;
iDoTheThing++;
if ( iDoTheThing == 60000 )
xEventGroupSetBitsFromISR( eg, evtDoTheSunLampThing, &xHigherPriorityTaskWoken );
iDoTheThing = 0;
gpio_config_t io_cfg = {};
io_cfg.mode = GPIO_MODE_OUTPUT;
//bit mask of the pins to set
io_cfg.pin_bit_mask = ( (1ULL << GPIO_NUM_15) );
//configure GPIO with the given settings
gpio_config(&io_cfg);
REG_WRITE(GPIO_OUT_W1TC_REG, BIT15); // sunlamp
/* Use 4th timer of 4.
1 tick 1/(80MHZ/80) = 1us set divider 80 and count up.
Attach onTimer function to timer
Set alarm to call timer ISR, every 1000uS and repeat / reset ISR (true) after each alarm
Start an timer alarm
timer = timerBegin( 3, 80, true );
timerAttachInterrupt( timer, &onTimer, true );
timerAlarmWrite(timer, 1000, true);
timerAlarmEnable(timer);
for ( int i = 0; i < (300 - 1); i++ )
strPayload[i] = '\0';
str_eTopic.reserve(300);
eg = xEventGroupCreate();
sema_MQTT_Parser = xSemaphoreCreateBinary();
sema_DoTheSunLampThing = xSemaphoreCreateBinary();
sema_MQTT_KeepAlive = xSemaphoreCreateBinary();
xSemaphoreGive( sema_DoTheSunLampThing );
xSemaphoreGive( sema_MQTT_KeepAlive ); // found keep alive can mess with a publish, stop keep alive during publish
xTaskCreatePinnedToCore( fparseMQTT, "fparseMQTT", 7000, NULL, 5, NULL, 1 ); // assign all to core 1, WiFi in use.
xTaskCreatePinnedToCore( MQTTkeepalive, "MQTTkeepalive", 7000, NULL, 2, NULL, 1 ); //this task makes a WiFi and MQTT connection.
xTaskCreatePinnedToCore( fDoTheSunLampThing, "fDoTheSunLampThing", 2000, NULL, 3, NULL, 1 );
} //setup() END
void GetTheTime()
char* ntpServer = "2.us.pool.ntp.org";
int gmtOffset_sec = -(3600 * 7 );
int daylightOffset_sec = 3600;
configTime(gmtOffset_sec, daylightOffset_sec, ntpServer);
// http://www.cplusplus.com/reference/ctime/strftime/
int getHour()
struct tm timeinfo;
getLocalTime(&timeinfo);
char _time[ 5 ];
strftime( _time, 80, "%T", &timeinfo );
return String(_time).toInt();
void printLocalTime()
struct tm timeinfo;
char _time[ 80 ];
log_i( "%s", _time);
void fDoTheSunLampThing( void * parameter )
// int x = gpio_get_level( GPIO_NUM_15 ); // reads gpio pin state returns an int
// SunLampManual = sunlamp on manual mode, automatic mode off for manual mode to work
// SunLampAuto = sun lamp enable automatic mode
bool AlreadyOn = false;
for (;;)
xEventGroupWaitBits (eg, evtDoTheSunLampThing, pdTRUE, pdTRUE, portMAX_DELAY );
vTaskDelay( 6 );
xSemaphoreTake( sema_DoTheSunLampThing, portMAX_DELAY );
// sun lamp on/off auto disabled
if ( (SunLampManual == 1) && (SunLampAuto == 0) )
if ( !AlreadyOn )
REG_WRITE(GPIO_OUT_W1TS_REG, BIT15);
AlreadyOn = true;
AlreadyOn = false;
} else if ( (SunLampManual == 0) && (SunLampAuto == 1) ) // light off auto enabled
int _hour = getHour();
if ( (_hour >= 7) && (_hour <= 17) )
AlreadyOn = true;
if ( (_hour < 7) || (_hour > 16) )
AlreadyOn = false;
AlreadyOn = false;
//log_i( "fDoTheSunLampThing high watermark %d", uxTaskGetStackHighWaterMark( NULL ) );
vTaskDelete( NULL );
} // void fDoTheSunLampThing( void * parameter )
Important to not set vtaskDelay to less then 10. Errors begin to develop with the MQTT and network connection.
makes the initial wifi/mqtt connection and works to keeps those connections open.
void MQTTkeepalive( void *pvParameters )
// setting must be set before a mqtt connection is made
MQTTclient.setKeepAlive( 90 ); // setting keep alive to 90 seconds
for (;;)
if ( (wifiClient.connected()) && (WiFi.status() == WL_CONNECTED) )
xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY ); //
MQTTclient.loop();
else {
log_i( "MQTT keep alive found MQTT status %s WiFi status %s", String(wifiClient.connected()), String(WiFi.status()) );
if ( !(WiFi.status() == WL_CONNECTED) )
connectToWiFi();
connectToMQTT();
vTaskDelay( 250 );
vTaskDelete ( NULL );
void connectToMQTT()
log_i( "connect to mqtt" );
// create client ID from mac address
String clientID = String(mac[0]) + String(mac[5]) ;
log_i( "connect to mqtt clientID %s", clientID );
while ( !MQTTclient.connected() )
MQTTclient.connect( clientID.c_str(), mqtt_username, mqtt_password );
log_i( "connecting to MQTT" );
vTaskDelay( 250 );
log_i("MQTT Connected");
MQTTclient.setCallback( mqttCallback );
MQTTclient.subscribe( mqtt_topic );
void connectToWiFi()
log_i( "connect to wifi" );
while ( WiFi.status() != WL_CONNECTED )
WiFi.disconnect();
WiFi.begin( SSID, PASSWORD );
log_i(" waiting on wifi connection" );
vTaskDelay( 4000 );
log_i( "Connected to WiFi" );
WiFi.macAddress(mac);
log_i( "mac address %d.%d.%d.%d.%d", mac[0], mac[1], mac[2], mac[3], mac[4], mac[5] );
WiFi.onEvent( WiFiEvent );
GetTheTime();
printLocalTime();
void fparseMQTT( void *pvParameters )
xSemaphoreGive ( sema_MQTT_Parser );
for (;;)
xEventGroupWaitBits (eg, evtParseMQTT, pdTRUE, pdTRUE, portMAX_DELAY ); //
xSemaphoreTake( sema_MQTT_Parser, portMAX_DELAY );
if ( String(str_eTopic) == topic_SunLampOn )
SunLampManual = String(strPayload).toInt();
if ( String(str_eTopic) == topic_SunLampEnable )
SunLampAuto = String(strPayload).toInt();
// clear pointer locations
str_eTopic = ""; //clear string buffer
xSemaphoreGive( sema_MQTT_Parser );
} // void fparseMQTT( void *pvParameters )
// Important to get as much code out of the callback for realible operations.
static void mqttCallback(char* topic, byte * payload, unsigned int length)
xSemaphoreTake( sema_MQTT_Parser, portMAX_DELAY);
str_eTopic = topic + '\0';
int i = 0;
for ( i; i < length; i++) {
strPayload[i] = ((char)payload[i]);
//log_i( "topic %s payload %s" ,str_eTopicPtr, strPayloadPtr );
xEventGroupSetBits( eg, evtParseMQTT ); // trigger tasks
} // void mqttCallback(char* topic, byte* payload, unsigned int length)
// great trouble shooting tool when uncommented
void WiFiEvent(WiFiEvent_t event)
// log_i( "[WiFi-event] event: %d\n", event );
switch (event) {
case SYSTEM_EVENT_STA_CONNECTED:
log_i("Connected to access point");
case SYSTEM_EVENT_STA_DISCONNECTED:
log_i("Disconnected from WiFi access point");
case SYSTEM_EVENT_AP_STADISCONNECTED:
log_i("WiFi client disconnected");
default: break;
void loop() { }
