Hi, absolute beginner here.
I'm building a automated irrigation system using these parts:
Arduino Uno
DS1307RTC
Grove Capacitive Soil Moisture Sensor
2x 3v Solenoid Valves
2x 3.7v Li-ion batteries 6800mAh
The process is as follows:
If time=5am
then check soil moisture
if soil moisture =>560
then Solenoid Valves = ON
wait 10mins
Solenoid Valves = OFF
If time =7pm
wait 10mins
My code is as follows:
#include <Wire.h>
#include "DS1307.h"
DS1307 clock;//define a object of DS1307 class
const int SOLENOID = 13;
int sensorValue = analogRead(A0);
pinMode(SOLENOID, OUTPUT);
clock.begin();
clock.fillByYMD(2021, 6, 29); //Jan 19,2013
clock.fillByHMS(04, 59, 50); //15:28 30"
clock.fillDayOfWeek(TUE);//Saturday
clock.setTime();//write time to the RTC chip
printTime();
switch(clock.hour){
case 5:
if (sensorValue>560){
digitalWrite(SOLENOID, HIGH);
delay(600000);
digitalWrite(SOLENOID, LOW);
delay(3600000);
case 19:
delay(600000);
delay(3600000);
/Function: Display time on the serial monitor/
void printTime() {
clock.getTime();
Serial.print(clock.hour, DEC);
Serial.print(":");
Serial.print(clock.minute, DEC);
Serial.print(":");
Serial.print(clock.second, DEC);
Serial.print(" ");
Serial.print(clock.dayOfMonth, DEC);
Serial.print("/");
Serial.print(clock.month, DEC);
Serial.print("/");
Serial.print(clock.year + 2000, DEC);
Serial.print(" ");
Serial.print(clock.dayOfMonth);
Serial.print("*");
switch (clock.dayOfWeek) { // Friendly printout the weekday
case MON:
Serial.print("MON");
case TUE:
Serial.print("TUE");
case WED:
Serial.print("WED");
case THU:
Serial.print("THU");
case FRI:
Serial.print("FRI");
case SAT:
Serial.print("SAT");
case SUN:
Serial.print("SUN");
Serial.println(" ");
For some reason, when it hits 5am, the RTC stops printing time in the serial monitor and does not resume after.
No error messages are turning up, so I'm not sure what I'm doing wrong.
