Automated MPU6050 Calibration
Hi everyone,
I want to automate the calibration process for the MPU6050 (accelerometer+gyroscope) for the Arduino.
My idea is that I can implement a button on the Android App then it will send a variable via BT to the Arduino, then it will operate the calibration process.
I'm wondering if there is anyone here familiar with this topic and can provide me with some insight on the direction I should use to approach this task?
Thank you in advance,
Cookie
What is your current calibration process?
This is the current calibration code I want to automate
// I2Cdev and MPU6050 must be installed as libraries
#include "I2Cdev.h"
#include "MPU6050.h"
#include "Wire.h"
///////////////////////////////////   CONFIGURATION   /////////////////////////////
//Change this 3 variables if you want to fine tune the skecth to your needs.
int buffersize=1000;     //Amount of readings used to average, make it higher to get more precision but sketch will be slower  (default:1000)
int acel_deadzone=8;     //Acelerometer error allowed, make it lower to get more precision, but sketch may not converge  (default:8)
int giro_deadzone=1;     //Giro error allowed, make it lower to get more precision, but sketch may not converge  (default:1)
// default I2C address is 0x68
// specific I2C addresses may be passed as a parameter here
// AD0 low = 0x68 (default for InvenSense evaluation board)
// AD0 high = 0x69
//MPU6050 accelgyro;
MPU6050 accelgyro(0x68); // <-- use for AD0 high
int16_t ax, ay, az,gx, gy, gz;
int mean_ax,mean_ay,mean_az,mean_gx,mean_gy,mean_gz,state=0;
int ax_offset,ay_offset,az_offset,gx_offset,gy_offset,gz_offset;
///////////////////////////////////   SETUP   ////////////////////////////////////
 // join I2C bus (I2Cdev library doesn't do this automatically)
 Wire.begin();
 // COMMENT NEXT LINE IF YOU ARE USING ARDUINO DUE
 TWBR = 24; // 400kHz I2C clock (200kHz if CPU is 8MHz). Leonardo measured 250kHz.
 // initialize serial communication
 // initialize device
 accelgyro.initialize();
 // wait for ready
 while (Serial.available() && Serial.read()); // empty buffer
 while (!Serial.available()){
   Serial.println(F("Send any character to start sketch.\n"));
   delay(1500);
 while (Serial.available() && Serial.read()); // empty buffer again
 // start message
 Serial.println("\nMPU6050 Calibration Sketch");
 delay(2000);
 Serial.println("\nYour MPU6050 should be placed in horizontal position, with package letters facing up. \nDon't touch it until you see a finish message.\n");
 delay(3000);
 // verify connection
 Serial.println(accelgyro.testConnection() ? "MPU6050 connection successful" : "MPU6050 connection failed");
 // reset offsets
 accelgyro.setXAccelOffset(0);
 accelgyro.setYAccelOffset(0);
 accelgyro.setZAccelOffset(0);
 accelgyro.setXGyroOffset(0);
 accelgyro.setYGyroOffset(0);
 accelgyro.setZGyroOffset(0);
///////////////////////////////////   LOOP   ////////////////////////////////////
 if (state==0){
   Serial.println("\nReading sensors for first time...");
   meansensors();
   state++;
 if (state==1) {
   Serial.println("\nCalculating offsets...");
   calibration();
   state++;
 if (state==2) {
   meansensors();
   Serial.println("\nFINISHED!");
   Serial.print("\nSensor readings with offsets:\t");
   Serial.print(mean_ax);
   Serial.print("\t");
   Serial.print(mean_ay);
   Serial.print("\t");
   Serial.print(mean_az);
   Serial.print("\t");
   Serial.print(mean_gx);
   Serial.print("\t");
   Serial.print(mean_gy);
   Serial.print("\t");
   Serial.println(mean_gz);
   Serial.print("Your offsets:\t");
   Serial.print(ax_offset);
   Serial.print("\t");
   Serial.print(ay_offset);
   Serial.print("\t");
   Serial.print(az_offset);
   Serial.print("\t");
   Serial.print(gx_offset);
   Serial.print("\t");
   Serial.print(gy_offset);
   Serial.print("\t");
   Serial.println(gz_offset);
   Serial.println("\nData is printed as: acelX acelY acelZ giroX giroY giroZ");
   Serial.println("Check that your sensor readings are close to 0 0 16384 0 0 0");
   Serial.println("If calibration was succesful write down your offsets so you can set them in your projects using something similar to mpu.setXAccelOffset(youroffset)");
   while (1);
///////////////////////////////////   FUNCTIONS   ////////////////////////////////////
void meansensors(){
 long i=0,buff_ax=0,buff_ay=0,buff_az=0,buff_gx=0,buff_gy=0,buff_gz=0;
 while (i<(buffersize+101)){
   // read raw accel/gyro measurements from device
   accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
   if (i>100 && i<=(buffersize+100)){ //First 100 measures are discarded
     buff_ax=buff_ax+ax;
     buff_ay=buff_ay+ay;
     buff_az=buff_az+az;
     buff_gx=buff_gx+gx;
     buff_gy=buff_gy+gy;
     buff_gz=buff_gz+gz;
   if (i==(buffersize+100)){
     mean_ax=buff_ax/buffersize;
     mean_ay=buff_ay/buffersize;
     mean_az=buff_az/buffersize;
     mean_gx=buff_gx/buffersize;
     mean_gy=buff_gy/buffersize;
     mean_gz=buff_gz/buffersize;
   i++;
   delay(2); //Needed so we don't get repeated measures
void calibration(){
 ax_offset=-mean_ax/8;
 ay_offset=-mean_ay/8;
 az_offset=(16384-mean_az)/8;
 gx_offset=-mean_gx/4;
 gy_offset=-mean_gy/4;
 gz_offset=-mean_gz/4;
 while (1){
   int ready=0;
   accelgyro.setXAccelOffset(ax_offset);
   accelgyro.setYAccelOffset(ay_offset);
   accelgyro.setZAccelOffset(az_offset);
   accelgyro.setXGyroOffset(gx_offset);
   accelgyro.setYGyroOffset(gy_offset);
   accelgyro.setZGyroOffset(gz_offset);
   meansensors();
   Serial.println("...");
   if (abs(mean_ax)<=acel_deadzone) ready++;
   else ax_offset=ax_offset-mean_ax/acel_deadzone;
   if (abs(mean_ay)<=acel_deadzone) ready++;
   else ay_offset=ay_offset-mean_ay/acel_deadzone;
   if (abs(16384-mean_az)<=acel_deadzone) ready++;
   else az_offset=az_offset+(16384-mean_az)/acel_deadzone;
   if (abs(mean_gx)<=giro_deadzone) ready++;
   else gx_offset=gx_offset-mean_gx/(giro_deadzone+1);
   if (abs(mean_gy)<=giro_deadzone) ready++;
   else gy_offset=gy_offset-mean_gy/(giro_deadzone+1);
   if (abs(mean_gz)<=giro_deadzone) ready++;
   else gz_offset=gz_offset-mean_gz/(giro_deadzone+1);
   if (ready==6) break;
Please edit your post and insert code tags ("</>" button).
