Automatic gate (troubleshotting)
Hi!
im trying to do a automatic gate, and i can't put my reedswitch2 working (start sensor)
I want my project to look like an automatic gate, so if i press the button "▼" i want the gate to open automaticaly, and when i press the button "▲" i want the gate to close. The objective to have 2 reedswitches is to when is detects one of them the arduino knows that the gate is closed and when it detecs the other, arduino knows that the gate is open.
In this code im not able to make it work because it is giving an error in the if statement.
I would apreciate some help.
This is the code i used:
//Defenir pins e variaveis
#include <IRremote.h>
#define IN1 2 //K1、K2 motor direction
#define IN2 4 //K1、K2 motor direction
#define ENA 5 // Needs to be a PWM pin to be able to control motor speed ENA
#define ENB 6 // Needs to be a PWM pin to be able to control motor speed ENA
#define IRPIN 3 //IR receiver Signal pin connect to Arduino pin 4
#define switchReed1 1 // Reed switch pin 1
#define switchReed2 0 // Reed switch pin 0
#define IR_ADVANCE 0x00FF18E7 //code from IR controller "▲" button
#define IR_BACK 0x00FF4AB5 //code from IR controller "▼" button
#define LED_G 10
#define LED_R 9
enum DN
GO_ADVANCE, //go ahead
GO_BACK,//go back
DEF
}Drive_Num=DEF;
IRrecv IR(IRPIN); // IRrecv object IR get code from IR remoter
decode_results IRresults;
bool stopFlag = true;//set stop flag
bool JogFlag = false;
uint16_t JogTimeCnt = 0;
uint32_t JogTime=0;
/motor control/
void go_back(int t) //motor rotate clockwise -->robot go ahead
digitalWrite(IN1, LOW);
digitalWrite(IN2, HIGH);
delay(t);
void go_ahead(int t) //motor rotate counterclockwise -->robot go back
digitalWrite(IN1, HIGH);
digitalWrite(IN2, LOW);
delay(t);
void go_stop() //motor brake -->robot stop
/*set motor speed */
void set_motorspeed(int lspeed,int rspeed) //change motor speed
analogWrite(ENA,lspeed);//lspeed:0-255
analogWrite(ENB,rspeed);//rspeed:0-255
/detect IR code*/
void do_IR_Tick()
if(IR.decode(&IRresults))
if(IRresults.value==IR_ADVANCE)
Drive_Num=GO_ADVANCE;
else if(IRresults.value==IR_BACK)
Drive_Num=GO_BACK;
IRresults.value = 0;
IR.resume();
/car control/
void do_Drive_Tick()
switch (Drive_Num)
case GO_ADVANCE:
set_motorspeed(140,140);go_ahead(20);JogFlag = true;JogTimeCnt = 3;JogTime=millis();break;//if GO_ADVANCE code is detected, then go advance
case GO_BACK:
set_motorspeed(140,140);go_back(20);JogFlag = true;JogTimeCnt = 1;JogTime=millis();break;//if GO_BACK code is detected, then backward
default:break;
Drive_Num=DEF;
{ if (digitalRead(switchReed1) == LOW) { //Se o circuito estiver fechado
digitalWrite(LED_R, LOW); //LED verde
digitalWrite(LED_G, HIGH);
digitalWrite(LED_R, HIGH); //LED vermelho
digitalWrite(LED_G, LOW);
if (digitalRead(switchReed2) == LOW) { //Se o circuito estiver fechado
digitalWrite(LED_R, LOW); //Sem LED
do_IR_Tick();
do_Drive_Tick();
/L298N/
pinMode(IN1, OUTPUT);
pinMode(IN2, OUTPUT);
pinMode(ENA, OUTPUT);
pinMode(ENB, OUTPUT);
pinMode(LED_R, OUTPUT);
pinMode(LED_G, OUTPUT);
pinMode(switchReed1, INPUT);
pinMode(switchReed2, INPUT);
pinMode(IRPIN, INPUT);
What error would that be? Sort of lacking in information necessary to help.
exit status 1
too few arguments to function 'int digitalRead(uint8_t)'
This is the error that i'am getting
The error I'm seeing is 'no tags'
I don't see
in your code. Did you post all of it?
Doesn't look like correct format either. Did that come from the library you call out?
This code have some errors and i want help to fix this.
The code working, but after i tryed add the second reedswitch this stoped work.
This is the part: (bold part)
do_IR_Tick();
do_Drive_Tick();
Still can’t see your ... ?
what?
what?
Still can't see your ...
what code ?
I send the code before of that.
this is where i found the error
Forum Etiquette - and it will help the people that want to help you...
what man i dont understand wht u re saying
Last post...
I’ll give another hint...
READ THE FORUM STICKIES ABOUT POSTING CODE.
what is the problem ?
The problem is that you are not posting your code using the code tags as described in point 7 of "How to Use this Forum".
Use of code tags is a "Skills Filter". If you can't figure out how to use code tags, you will never be able to figure out the problem with your code, and we will choose to spend our time with posters who have a better chance of success.
