Automatic Irrigation System with two moisture sensors
Hello, everyone!
I want to build automatic irrigation system with two pumps and two moisture sensors. I want to achieve that each moisture sensor is connected to one pump. I was successful with one moisture sensor and pump, but I failed to achieve that for the second sensor. I tried to change the code in many ways, but nothing works. I would appreciate any help with this issue.
This is the code:
int relayPin = 4;
int relayPin1 = 3;
int sensor_pin = A0;
int sensor_pin1 = A1;
int output_value1;
int output_value;
  pinMode(relayPin, OUTPUT);
  pinMode(sensor_pin, INPUT);
  pinMode(relayPin1, OUTPUT);
  pinMode(sensor_pin1, INPUT);
  Serial.println("Reading From the Sensor...");
  delay(2000);
  output_value = analogRead(sensor_pin);
  output_value = map(output_value, 550, 10, 0, 100);
  Serial.print(output_value);
  Serial.println("%");
  if (output_value < 20) {
    digitalWrite(relayPin, HIGH);
    digitalWrite(relayPin, LOW);
  output_value1 = analogRead(sensor_pin1);
  output_value1 = map(output_value1, 550, 10, 0, 100);
  Serial.print(output_value1);
  if (output_value1 < 20) {
    digitalWrite(relayPin1, HIGH);
    digitalWrite(relayPin1, LOW);
What do your Serial.prints look like? Are you powering the relays from the Arduino's 5V pin? How are you powering the Arduino? How are you supplying power for the pumps? What is the pumps' voltage and current ratings?
The Serial.print looks like this one sensor works another not
03:06:08.370 -> -11%
03:06:08.370 -> 101%
Yes, I am powering the relay from the Arduino 5V pin.
The Arduino Uno R4 Wifi is powered via USB to the computer.
The pumps are soldered with a USB cable, plugged into a 5v adapter and attached to the relay.
I use a mini submersible pump the voltage is DC 3V/6V, and for 5V the current is 120mA.
Are the sensors in exactly the same environment? if so, one looks faulty.
Give me a few minutes to rearrange your code.
See if this works, I double read the sensor values, compiles but I don't have the hardware to test.
const byte relayPin1 = 4,
           relayPin2 = 3,
           sensor_pin1 = A0,
           sensor_pin2 = A1;
int output_value1;
int output_value2;
  pinMode(relayPin2, OUTPUT);
  delay(2000);
  output_value2 = analogRead(sensor_pin2);
  output_value2 = map(output_value2, 550, 10, 0, 100);
  Serial.print(output_value2);
  digitalWrite(relayPin1, output_value1 < 20);
  digitalWrite(relayPin2, output_value2 < 20);
I tried to switch to another sensor.No luck. I used your code to upload. Same thing only one sensor works another just ignores everything. Especially the relay LED on first sensor it turns normally, but for the second it just stays on all the time.
If both sensors are dry, what do the read? If submerged in water? If you switch sensor1's wire to A1 and sensor2's wire to A0, what do they read? Post a photo of the sensors.
Hi, @lesovihs
Welcome to the forum.
Thanks for using code tags. :+1:
Have you written some simple code that JUST reads your moisture sensors, does nothing else, to prove your hardware connections.
If not then please do it to prove your input circuit/
Do you have a DMM? (Digital MultiMeter)
Can you please post a link to specs/data of your moisture sensor?
Thanks.. Tom.. :smiley: :+1: :coffee: :australia:
And you could remove the relays for the moment, and replace each with a LED with series current limiting resistor to see if you maybe have another issue.
The code looks OK from under the umbrella here.
One small change woukd make the diagnostic sketch output easier to interpret:
  Serial.print("Sensor 1 : ");
  Serial.println(output_value1);
  Serial.print("Sensor 2 :                                  ");
  Serial.println(output_value2);
Never mind why I know so much about diagnostical printing. :expressionless:
But mostly I just wanted to say crazy pants! Nice.
a7
Good point, TNX.
Hello everyone! I found the issue. It turns out that the second sensor was connected to Vin, but it was supposed to be connected to 3.3v. I fixed it and now everything works as a charm.
Thank you everyone for your help!
