Hi guys, I want to have this code set to execute automatically at 8pm and then stop around 1am. I have no clue how to do this so I was wondering if someone would be so kind as to help me out?
long time; // variable for speed debug
float pwmSpeed[14] = {
0, 0, 1.2, 1.3, 1.4, 1.9, .9, .8, .5, 1.2, 1.37, 1.47, .3, 3.2}; // these constants set the rate of dimming
int pwmVal[14]; // PWM values for 12 channels - 0 & 1 included but not used
float pwmFloats[14];
int i, j, k, l, x, y, z, bufsize, pot; // variables for various counters
unsigned char sinewave[] = //256 values
0x80,0x83,0x86,0x89,0x8c,0x8f,0x92,0x95,0x98,0x9c,0x9f,0xa2,0xa5,0xa8,0xab,0xae,
0xb0,0xb3,0xb6,0xb9,0xbc,0xbf,0xc1,0xc4,0xc7,0xc9,0xcc,0xce,0xd1,0xd3,0xd5,0xd8,
0xda,0xdc,0xde,0xe0,0xe2,0xe4,0xe6,0xe8,0xea,0xec,0xed,0xef,0xf0,0xf2,0xf3,0xf5,
0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfc,0xfd,0xfe,0xfe,0xff,0xff,0xff,0xff,0xff,
0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfe,0xfd,0xfc,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7,
0xf6,0xf5,0xf3,0xf2,0xf0,0xef,0xed,0xec,0xea,0xe8,0xe6,0xe4,0xe2,0xe0,0xde,0xdc,
0xda,0xd8,0xd5,0xd3,0xd1,0xce,0xcc,0xc9,0xc7,0xc4,0xc1,0xbf,0xbc,0xb9,0xb6,0xb3,
0xb0,0xae,0xab,0xa8,0xa5,0xa2,0x9f,0x9c,0x98,0x95,0x92,0x8f,0x8c,0x89,0x86,0x83,
0x80,0x7c,0x79,0x76,0x73,0x70,0x6d,0x6a,0x67,0x63,0x60,0x5d,0x5a,0x57,0x54,0x51,
0x4f,0x4c,0x49,0x46,0x43,0x40,0x3e,0x3b,0x38,0x36,0x33,0x31,0x2e,0x2c,0x2a,0x27,
0x25,0x23,0x21,0x1f,0x1d,0x1b,0x19,0x17,0x15,0x13,0x12,0x10,0x0f,0x0d,0x0c,0x0a,
0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x03,0x02,0x01,0x01,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x02,0x03,0x03,0x04,0x05,0x06,0x07,0x08,
0x09,0x0a,0x0c,0x0d,0x0f,0x10,0x12,0x13,0x15,0x17,0x19,0x1b,0x1d,0x1f,0x21,0x23,
0x25,0x27,0x2a,0x2c,0x2e,0x31,0x33,0x36,0x38,0x3b,0x3e,0x40,0x43,0x46,0x49,0x4c,
0x4f,0x51,0x54,0x57,0x5a,0x5d,0x60,0x63,0x67,0x6a,0x6d,0x70,0x73,0x76,0x79,0x7c
void setup(){
DDRD=0xFC; // direction variable for port D - make em all outputs except serial pins 0 & 1
DDRB=0xFF; // direction variable for port B - all outputs
void loop(){
// time = millis(); // this was to test the loop speed
// for (z=0; z<1000; z++){ // ditto
// pot = analogRead(0); // this implemented a potentiometer speed control to control speed of fading
for (y=0; y<14; y++){ // calculate one new pwm value every time through the control loop
j = (j + 1) % 12; // calculate a new j every time - modulo operator makes it cycle back to 0 after 11
k = j + 2; // add 2 tp tje result - this yields a cycle of 2 to 13 for the channel (pin) select numbers
pwmFloats[k] = (pwmFloats[k] + pwmSpeed[k]);
// pwmFloats[k] = (pwmFloats[k] + ((pwmSpeed[k] * 15 * (float)pot) / 1023)); // implements potentiometer speed control - see line above
if (pwmFloats[k] >= 256){ // wrop around sinewave table index values that are larger than 256
pwmFloats[k] = pwmFloats[k] - 256;
else if (pwmFloats[k] < 0){
pwmFloats[k] = pwmFloats[k] + 256; // wrop around sinewave table index values that are less than 0
pwmVal[k] = sinewave[(int)pwmFloats[k]]; // convert the float value to an integer and get the value out of the sinewave index
PORTD = 0xFC; // all outputs except serial pins 0 & 1
PORTB = 0xFF; // turn on all pins of ports D & B
for (z=0; z<3; z++){ // this loop just adds some more repetitions of the loop below to cut down on the time overhead of loop above
// increase this until you start to preceive flicker - then back off - decrease for more responsive sensor input reads
for (x=0; x<256; x++){
for( i=2; i<14; i++){ // start with 2 to avoid serial pins
if (x == pwmVal[i]){
if (i < 8){ // corresponds to PORTD
// bitshift a one into the proper bit then reverse the whole byte
// equivalent to the line below but around 4 times faster
// digitalWrite(i, LOW);
PORTD = PORTD & (~(1 << i));
else{
PORTB = PORTB & (~(1 << (i-8))); // corresponds to PORTB - same as digitalWrite(pin, LOW); - on Port B pins
// Serial.println((millis() - time), DEC); // speed test code
