Automatic packaging machine
Hie guys
I am developing a simple automatic packaging machine which you key in the quantity you want to measure then a valve is opened to allow the liquid into a plastic while measuring and closes the valve when weight on the scale is equal to desired weight. My problem now is on having a program to control my motorised valve so that as the difference between the desired weight and the measured weight is reduced the valve will also be closing accordingly.
I am stuck. I am using load cells for my scale and a 12v motorised valve for my dispensing control
Hie guys
I am stuck.
I sometimes pre-pay at the fuel pump. I tell the station attendant the amount I want and they enter it into the pump control software (the register). The pump starts out running at full volume. But as the pump approaches the full purchase amount, it slows to a trickle. Then it shuts off right at the full purchase amount.
This slow down before shutdown increases the accuracy.
Chaperone: Hie guys
How much time is required for your motorized valve to open and close?
Paul
I am stuck.
Doing what, and why?
@Chaperone, do not cross-post. Threads merged.
Hey, does your problem solved? I find i also meet this problem.
