i am an engineering student. for my final year project i need to use a laser range finder.For my project i need to align the sensor to a particular object and take measurement,also am using a pan and tilt unit for the same. I am also using a camera to view the object ,my question is- how do i make the sensor point to the point i selected on the screen. i need the sensor to automatically align itself to the point i select.
actully i want the sensor to point at the object not the camera to track it. is there any way i can do that
You might make a crude setup somewhat similar to a solar tracker. If you can modulate the laser beam at 38khz then you might be able to detect the laser spot more readily with an IR detector type of setup.
