Automatic skylight hatch
Hi Folks,
I'm new to Arduino, so please be gentle on me :slight_smile:
I'm currently carrying out a project for college.
I am planning to install a automatic skylight hatch for my house.
It has to open and close automatically when the temperature reaches a certain level
It also has to open and close when a certain level of light is detected
It has to incorporate a time clock and a override switch.
I intend to use a Arduino Uno,
Has anyone attempted anything like this?
I would be grateful for any advise and help
Do the mechanical design first.
Paul
Buy an Uno.
Install the IDE and play around with the example sketches. Get to understand them.
Look at some examples for switches. Get your "override" switch working...
get a real-time clock (RTC) and get it working
get a temperature sensor and get it working
get a light detector and get it working
Figure out how you are going to open/close your skylight - it will take a lot of power, more than the Arduino can deliver.
Then start incorporating it all together. I'd say this is a pretty ambitious first project - Good Luck!
Thanks Blh64,
I only have to do a prototype and not the full project, thankfully so i don't need to worry about getting the correct actuator.
It is just the control system that i have to concentrate on.
thanks for your guidance
The outline in reply #2 is nevertheless the way you need to proceed, if you want to avoid endless frustration.
You could use an LED in place of the actuator to demonstrate functionality.
You might want to detect rain too !
