Automatic Switcher
Is there any electronic component which can switch between some channels with only 1 input which channel it should take?
Hmmm, Magic 8 ball says....Try again later, more info needed. :relaxed:
i want to switch between 2 "cables" with one input here a schematic:
OUTPUT CHANNELS 1 2 | | | | /_/\
| S | S = Switcher, controlled by INPUT which is an electrical signal
| | | INPUT
(deleted)
input or output? both electrical voltage signal
Look at CD4051, 4052 or 4053 if it's analog signals to switch. If it's digital signal use an 74HC00.
Pelle
i found this? is it right? can u explain me how to use? http://www.conrad.de/ce/de/product/164178/CMOS-IC-Texas-Instruments-74HC00N-Gehaeuseart-DIP-14-Ausfuehrung-4fach-NAND-Gatter-2-Eingaenge
Like this
can u explain more detailed pls?
