Hi, I need to discover the port number where arduino is connected to. I can use many languages like c++, java, processing but I need to autodetect the port in windows and osX. I have tried to use 'processing' and to scan all the available ports but when I speak to some busy port an exception arises. Do you know how can I solve this problem? Is it possible to obtain the device name in any program language? (I know it's in c# but only under windows).
Thanks in advance for your help
Use try/catch and catch the exception.
If it is possible in one, it is possible in all. Exactly how is dependent on the language.
Thanks for the answer
Using try and catch the program exits badly... This is the code:
try{
arduinoPort = new Serial(this, Serial.list()[i], 9600) ; // Open 1st port in list
catch (Exception e)
System.out.println("exc");
portaDisponibile=false;
arduinoPort.stop();
On the debug screen it is written:
gnu.io.PortInUseException: Unknown Application
at gnu.io.CommPortIdentifier.open(CommPortIdentifier.java:467)
at processing.serial.Serial.(Unknown Source)
at rilevaSeriale.setup(rilevaSeriale.java:59)
exc
at processing.core.PApplet.handleDraw(Unknown Source)
at processing.core.PApplet.run(Unknown Source)
at java.lang.Thread.run(Thread.java:722)
and at the end quitting the program:
Error 0x5
It is for this that I prefer to search for the right com using the device name and not try to handshake all of them
catch (Exception e)
A PortInUseException is not necessarily a Exception.
Using what device name?
PaulS:
what do you mean?
For example if go to control panel->system->devices I can find that my arduino is called as "arduino leonardo" by windows. The information is stored on the system register so may be I have to find a way to ask it from my code. I have no idea for osX
what do you mean?
You have registered to catch exceptions of type Exception. If PortInUseException is not derived from Exception, you can't catch it. Wrong kind of net.
Hello,
I am not 100% sure what your intended application is. But, I have had success in doing what you seek through the use of Visual Basics 2010. The Try/Catch functions work very well in VB 2010.
Another suggestion, you could have a on-board code that 'handshakes' with the program you designed. However, I don't think this would overcome your immediate problem of occupied Ports.
I hope I helped somewhat,
Good luck,
I've seen this work in Processing.
println(Arduino.list());
I was surprised to find that
arduino = new Arduino(this, Arduino.list()[0], 57600);
would need '0' to work. Two other ports are working and the Arduino-port is Port8. Ehmee .. maybe that's why my setup /doesn't/ work ..
See the extensive code I posted in
http://arduino.cc/forum/index.php/topic,115580.0.html
for a workable visual-basic solution.
Because println() is overloaded to take a list.
Why? The function's second argument is an item, not a list. The [ 0 ] part says which item from the list.
the problem is that with arduino.list() I obtain all the serial devices connected to my computer. I think for ddetecting arduino I must use a sort of handshake. The problem is that I need to listen to all the devices connected but if they are already busy (the com port is occcupied) an exception occours and from processing it seems not possible to catch the "PortInUseException". Any other suggestion to detect the port number with my arduino?
(PS: thanks to everyone that is giving me good advices to solve this problem!)
cantore:
Wouldn't that solve your problem? You can scrutinize each member-name in the list and have the index of the port you find.
A handshake are sometimes used as part of a start-communication and sometimes fixed by a formal protocol used. If you'r in a position to use a successful handshake, you've already found your port. But, ok, I see where you'r going. I'm not sure of what functions are available, but the set I used in vb needed an eqvivalent to serial.start() before any communication. If you can assume, that your board is in a closed state ... if it's got a isOpen() .. I don't know.
Well .. you can still set up a catch/try block ... but that way round may bring you to where your teachers told you not to go.
Paul,
you sure can catch me in the shortcomings of my expressions. I'm surprised that I get a sort of 'passed the array-limit' error on [2] when there are three available ports, that the third (arduino) on the list is available on [1] and that accessing [0] throws no error ... but how could you know ..
Carsten53T:
Can you suggest me how to do this please? This was the fist way I have tried to implement but I did not found any way to obtain the com devices names in both windows and osx (for example in windows is easy with C#, but this is another job...)
Check out Processing .. in modes/java/libraries/arduino/examples/arduino_output
size(470, 200);
On my pc println(Arduino.list()); prints the name ("Port8") of one (a port with an arduino attached) out of three ports. Outside println() Arduino.list() should be accessible for tabbing through .. right?
EDIT:
I completely forgot that it's a downloaded library
Look/get at it at
http://www.arduino.cc/playground/interfacing/processing
thanks Carsten53T, but the problem is that you obtain the name of the port, not of the device. So if I have 3 com busy, for example COM3 COM8 and COM10 it is not possible to automatically detect on wich one arduino is connected to.(of course if I know the port becouse I saw it from my OS I can set it manually but this is not what I need to do)
cantore:
cantore,
That's as far as I can take you.
The first time I attach a board to my pc .. I'll have to go through the procedure of finding the proper driver and 'install' it to the board. At that time, the board will be blessed with a port-name that appears to stick to that particular board and not the usb-port that it is connected to. I think that it'll be a mess to automate catching this portname as it would need an app running prior to the time you choose to connect a new board.
Even the ardino-editor doesn't do an automatic search .. atleast you may often find yourself have to choose which port to use. You can mimic that with gui in processing (make it show a drop-down list with available ports). I'm way too inexperienced to suggest what's available if you choose to look at 'port-methods' in c/c++.
Remember to pop a message if you succeed .. it would be a nice thing to master ..
I have done this successfully using Visual Studio Basic.
VB Code sends a "4" to all com ports in a loop test. Arduino code on boot looks for a "4" at the serial port. When it reads a "4" it sends back a "4" to confirm you have found the correct serial port.
Arduino code:
int x = 2;
// initialize serial:
Serial.flush();
Serial.write (4) ;
pinMode(10,OUTPUT);
pinMode(11,OUTPUT);
pinMode(12,OUTPUT);
pinMode(13,OUTPUT);
digitalWrite(10,LOW);
digitalWrite(11,LOW);
digitalWrite(12,LOW);
digitalWrite(13,LOW);
Serial.flush();
// send data only when you receive data:
while (Serial.available()==0);
int Incomming = Serial.read()-'0';
if (Incomming == 4){
delay (20) ;
Serial.write (4) ;
VB Code:
Imports System.IO
Imports System.IO.Ports
Imports System.Threading
Public Class Form1
Dim Serialport1 As SerialPort
Dim ArduinoPort As SerialPort
Dim Exists As Byte = 0
Dim Message As String
Dim ArdCOM As String
Dim InButtonPressed As Boolean
Dim OutButtonPressed As Boolean
Dim ButtonIn As Boolean
Dim ButtonOut As Boolean
Dim CanLoopGo As Boolean = False
Dim Direction As Integer = 0
Dim CNT As Integer = 0
Dim Start As Integer
Dim Finish As Integer
Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
For Each sp As String In My.Computer.Ports.SerialPortNames
TextBox1.Text = " " + (sp) + " Found" & Environment.NewLine
Serialport1 = New SerialPort(sp)
Serialport1.Open()
Show()
'Serialport1.ReadChar()
Serialport1.Write("4")
Delay(2)
TextBox1.Text = TextBox1.Text + " Diagnostic tests: OK"
Serialport1.ReadTimeout = 500
Try
Message = Serialport1.ReadChar()
TextBox1.Text = TextBox1.Text + " " & Environment.NewLine + " Serial Read: " + " " + Message & Environment.NewLine & Environment.NewLine
If Message.Contains("4") Then
ArduinoPort = Serialport1
Exists = 1
TextBox1.Text = TextBox1.Text + ("NinoFocus found: ") + (sp)
End If
Catch generatedExceptionName As TimeoutException
End Try
Next
If Exists = 0 Then
TextBox1.Text = ("No Focuser found.")
Button2.Enabled = False
Button3.Enabled = False
End If
' Calls
End Sub
VB Form looks like this:
Simple form with a
- multiline text box called Textbox1
- 3 buttons called Button1, Button2 and Button3
That's it!
Nino
You must add a Try/Catch also here
Serialport1.Open()
because if a Serial Port is in use you get an error.
