Hello, friend,
Really really..I'm sorry.
I'd like to know how to save files automatically in SD card with 'if' grammer or any other method.
So difficult to solve this problem because I'm a beginner.
Until now, I have to unplug the usb cable which connects arduino to computer, in order to save files and create new file.
My arduino system consists of Mega + RTC + SD reader.
I'd like to make this saving pattern to '1 csv file per 1 day'
automatically every day.
Please, let me know how to modify the below origin source code.
Thank you in advance.
------------------------------------------------- see below
RTC_DS1307 RTC;
const int chipSelect = 53;
File dataFile;
Serial.print("Initializing SD card...");
Wire.begin();
RTC.begin();
RTC.adjust(DateTime("Aug 16 2015","09:53:00"));
pinMode(SS, OUTPUT);
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
while (1) ;
Serial.println("card initialized.");
// open a new file if it doesn't exist and leave the loop:
char filename[] = "DATA_000.CSV";
for (uint8_t i = 0; i < 1000; i++) {
filename[5] = i/100 + '0';
filename[6] = (i%100)/10 + '0';
filename[7] = i%10 + '0';
if (! SD.exists(filename)) {
dataFile = SD.open(filename, FILE_WRITE);
if (! dataFile) {
Serial.println("could not create file");
Serial.print("Logging to: ");
Serial.println(filename);
int i = 0;
DateTime now = RTC.now();
// Sending date & time to UART every second
Serial.print(now.year(), DEC);
Serial.print('/');
Serial.print(now.month(), DEC);
Serial.print('/');
Serial.print(now.day(), DEC);
Serial.print(' ');
Serial.print(now.hour(), DEC);
Serial.print(':');
Serial.print(now.minute(), DEC);
Serial.print(':');
Serial.print(now.second(), DEC);
Serial.print(" ");
String dataString = "";
for (int analogPin = 0; analogPin < 3; analogPin++) {
int sensor = analogRead(analogPin);
dataString += String(sensor);
if (analogPin < 2) {
dataString += ",";
Serial.println(dataString);
dataFile.print(now.year(), DEC);
dataFile.print('/');
dataFile.print(now.month(), DEC);
dataFile.print(now.day(), DEC);
dataFile.print(' ');
dataFile.print(now.hour(), DEC);
dataFile.print(':');
dataFile.print(now.minute(), DEC);
dataFile.print(now.second(), DEC);
dataFile.print(",");
dataFile.println(dataString);
i++;
if (i>0){ //Call every times
dataFile.flush();
i = 0;
