Automobile electric throttle
Hello! I have a car with a manual throttle. I want to switch to electronic throttle and electric pedal. I need help writing code on Arduino for the driver to control the devices listed above. I would be very grateful for your help
Do you have this all wired up so you can test each step of the code you write?
Assuming this will be placed on a public road I will not answer because of the potential liability.
Before proceeding please consider what will happen if something fails and the engine goes full bore or stops on a roadway. Have you created a fail safe design compatible to the automotive electrical system?
Is your "car" a motor vehicle? If so your project has real danger if something fails. Even if you wish to take a risk, driving on public roads puts others are risk as well.
