I'm looking for an AVR chip which is available in PDIP or surface mount which is solderable by hand. I'm currently considering an attiny44 (ATTINY44V-15SST), but something like an attiny84 or even a 328 would be preferred. I've not found packages I like for the attiny84 or 238. Again, this is in the automotive classification, specifically because I require the heat range allowances. Is there a step up in flash size and friendly package for something that comparable to the automotive attiny44 which I've overlooked?
Do you need them in a particular form factor? I have some -AZ chips and offer boards that will make a small system on a chip kind of assembly. The crystal and some other Rs & Cs are on the back. http://www.crossroadsfencing.com/
328 is technically TQFP vs SOIC, but same suggestion applies. Solder down 1 or 2 corners for stability, then the rest. I have a stencil and apply solder paste and then use a reflow oven. Never get any shorts.
